Bosch Type 22 Magneto Help Needed
this thread has 4 replies and has been viewed 722 times
Old 07-17-2018, 09:51:39 PM
beechcraft1 beechcraft1 is offline
Default Bosch Type 22 Magneto Help Needed
I have a Bosch Type 22 flick magneto and I'm wondering if anyone can help me with date of manufacture. The serial number is #1835404. Looks like a brass mounting base. Thanks for any help.
John
Old 07-20-2018, 07:59:44 AM
Default Re: Bosch Type 22 Magneto Help Needed
I'll try this one more time, any info would be appreciated.
John
Old 07-20-2018, 09:19:07 AM
Ellis Wellman Ellis Wellman is offline
Small help--It is definitely after 1915.
Old 07-20-2018, 10:47:31 PM
Peter Short Peter Short is offline
This list of dates is fairly well known I think, probably refers to German-made Bosch.
I have a Type 22 No.1671140 which I know is original to its 1914 engine (it has the engine number stamped on it) and it fits this list i.e. 1913.
"After 1915" seems correct, but how did a wartime magneto get to Canada?
Old 07-22-2018, 10:39:15 PM
Thanks for the chart , any help is really appreciated. I had seen it and thought maybe I was missing something. Went back and took another look and noticed it also says "New York" in small stamped letters so I assume it came from or through the USA at some point. The mag must be original because it has original green paint same as the engine and you could tell the mag had never been off the engine. This mag is on a 7HP Manitoba engine if that helps. If anyone has a serial number list for Manitoba engines I'd appreciate if you could share it. Thanks for all of your input.
John
Bosch Type 32 low tension magneto Phil Dowe Smokstak Down Under 6 01-29-2017 03:08:33 AM
Bosch Type 22 Flick magneto roland servais Magnetos, Ignition Coils and Spark Plugs 3 06-21-2016 11:04:47 PM
IHC Type M with Bosch Magneto DaveM Magnetos, Ignition Coils and Spark Plugs 16 07-07-2011 06:58:57 PM
Bosch type 22 Magneto Dusty Magnetos, Ignition Coils and Spark Plugs 5 09-30-2010 08:24:08 PM
Help with Bosch type DA 2 magneto? Don H. Magnetos, Ignition Coils and Spark Plugs 0 03-27-2007 02:21:04 AM
