HELP to Identify Magneto Bracket (no number on the bracket)
this thread has 3 replies and has been viewed 425 times
Old 07-23-2018, 09:33:10 PM
MiqC2001 MiqC2001 is offline
Default HELP to Identify Magneto Bracket (no number on the bracket)
Hi, I found this bracket.
I don't know where that's bracket go...
If you may help me, tha't will be super !
I take mesure of the 2 hole for the installation onto the engine.
The inside hole mesure is 2 inches and outside is 3 inches. That's may helpfull ?
Thanks for your help !
Charles
ID:	314786   Click image for larger version
ID:	314787   Click image for larger version
ID:	314788   Click image for larger version
Old 07-23-2018, 10:07:31 PM
Jason Dahm Jason Dahm is offline
Default Re: HELP to identify magneto bracket (no number onto the bracket)
Pretty sure it's GS&M. Jason
The Following User Says Thank You to Jason Dahm For This Post:
Old 07-24-2018, 09:47:32 AM
Many Thanks Jason, did you know on wich model of Gould Shapley and Muir ?
Many thanks again !
Old 07-24-2018, 10:07:24 AM
I'm not sure but I think it fits several models and sizes. Jason
What is the Mag Bracket Number for Stover YB Vertical? Farmall Hit & Miss Gas Engine Discussion 1 04-17-2018 07:57:30 AM
Need Help to Identify Magneto and Bracket Dan thomas Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 01-25-2016 05:50:42 PM
Help Identify Magneto Bracket Tom Adkins Hit & Miss Gas Engine Discussion 2 01-22-2016 09:51:18 AM
Help identify this Webster mag bracket, please.... Andrew Walker Hit & Miss Gas Engine Discussion 1 09-18-2007 12:19:13 AM
Webster mag bracket number Dale Antique Engine Archives 3 07-11-2002 12:05:46 AM
