2 Cylinder Distributor
this thread has 6 replies and has been viewed 646 times
Old 07-25-2018, 10:11:18 PM
JD Canuck JD Canuck is offline
Default 2 Cylinder Distributor
I hope this works. Pictured above is a distributor I have which I believe is for an engine on a John Deere bailer. I have contacted Delco Remy but all they can tell me is that is discontinued and no info is available. I would appreciate it if anyone had information or knowledge for this item. Thanks in advance for any help you can provide me.
Old 07-26-2018, 02:32:18 AM
cobbadog cobbadog is offline
Default Re: 2 cylinder distributor
G'Day JD,
What sort of information are you after? This will help those who can offer an reply, otherwise it could be a bloody long novel you will get.
Old 07-26-2018, 06:21:53 AM
Elden DuRand's Avatar
Since the two towers are located 90 degrees apart, it is for an engine with a 180 degree (uneven firing) crankshaft.
Probably the most common 180 crank engines that use a distributor are the John Deere tractor engines, called "Johnny Poppers".
That doesn't mean the distributor is for a John Deere, though. I'm not a J. D. expert here.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 07-26-2018, 07:29:29 AM
Trying to find out what engine it was designed for.
---------- Post added at 07:29:29 AM ---------- Previous post was at 07:25:19 AM ----------
Thanks that makes sense, possibly some of the upright two tractors built by John Deere.
Old 07-26-2018, 09:21:16 AM
mmcdonald mmcdonald is offline
Much easier to look it up with the number on the tag(when present) rather than try to identify visually on some things. I can't make the tag number out.
Sorry I didn't notice the box picture. I'll try to look it up.
---------- Post added at 09:21:16 AM ---------- Previous post was at 09:07:56 AM ----------
My references aren't too good for outside the US but looks like it was sold in Canada. Looks like it fits "HD" engine made by Russel-Hipwell (in Canada) around 1949. Engine used to power log boom boats. All I can find easily and might be used in some other application.
info@mcdonaldcarb.com
Old 07-26-2018, 12:42:53 PM
hotrodzz4 hotrodzz4 is offline
Default Re: 2 Cylinder Distributor
https://ingeniumcanada.org/ingenium/...=1988.0264.001
Russell Hipwell Marine according to the specs in the link above.
The Following User Says Thank You to hotrodzz4 For This Post:
Old 07-26-2018, 09:44:07 PM
[/COLOR]My references aren't too good for outside the US but looks like it was sold in Canada. Looks like it fits "HD" engine made by Russel-Hipwell (in Canada) around 1949. Engine used to power log boom boats. All I can find easily and might be used in some other application.[/QUOTE]
Thank you so much, really appreciate the information.
---------- Post added at 09:44:07 PM ---------- Previous post was at 09:42:35 PM ----------
Russell Hipwell Marine according to the specs in the link above.[/QUOTE]
Thank you,
Atwater Kent K-3 Two Cylinder Distributor Nevr-Enuf-Stuf Magnetos, Ignition Coils and Spark Plugs 9 04-17-2017 10:00:07 AM
Can I get information on this 5 Cylinder Distributor? Seakaye12 Magnetos, Ignition Coils and Spark Plugs 4 11-16-2016 10:55:18 AM
Ford 18 Cylinder distributor Cap ? B-17 B-24? Jim Martin Magnetos, Ignition Coils and Spark Plugs 3 09-10-2013 09:14:04 PM
Distributor JD Canuck Magnetos, Ignition Coils and Spark Plugs 2 01-21-2012 10:58:19 PM
Distributor cap repair on military four cylinder dougimes Magnetos, Ignition Coils and Spark Plugs 9 10-09-2010 08:23:03 PM
