Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Detroit Model G - Brass Compression Fittings
this thread has 1 replies and has been viewed 482 times
Old 02-10-2019, 10:41:15 AM
Jeff Blaney Jeff Blaney is offline
Default Detroit Model G - Brass Compression Fittings
I am currently rebuilding a Detroit Model G, five port, force feed lubricator for my Moline Universal Tractor. At the point to do some testing with it, I have ran into a snag with the brass compression fittings at the discharge point of the lubricator.
The fittings are built to accept 1/4" tubing, but as you can see the original fittings have 22 threads per inch, while the modern fittings have 24 threads per inch. I am missing all of the the original 22 tpi nuts and cannot fasten the copper tubing to these discharge fittings.
Anybody else run into this issue before? What sorts of fittings are available with a 22 tpi thread pitch if any?
Thanks.
ID:	328314   Click image for larger version
ID:	328315   Click image for larger version
The Following 2 Users Say Thank You to Jeff Blaney For This Post:
Old 02-10-2019, 02:56:35 PM
Default Re: Detroit Model G - Brass Compression Fittings
Thinking some more about this issue, I was able to retrieve one of the few remaining oil lines, nuts and ferrules that was left on the tractor. As you can see the ferrule itself is a different design from the modern type. This makes sense as the taper on the new and old elbows is different as well.
Is this just old, obsolete technology or are there different ferrule/taper profiles still available these days?
ID:	328345   Click image for larger version
The Following User Says Thank You to Jeff Blaney For This Post:
Small Brass Model Fittings R. Kern Scale Model Engineering 3 02-26-2017 09:39:40 AM
Old vs New tube compression fittings JoeCB Antique Marine Engines and Outboard Motors 3 04-11-2014 04:15:53 PM
Information on Compression Fittings Vernon Rublee Hit & Miss Gas Engine Discussion 5 03-27-2011 01:28:18 PM
What year did compression fittings come out? bills Antique Engine Archives 0 05-31-2002 04:59:24 PM
model brass fittings tex holliday Antique Engine Archives 0 06-24-2000 04:24:13 PM
