1949 Case VAC/ Autolite distributor
this thread has 0 replies and has been viewed 4064 times
Old 11-09-2006, 05:16:55 PM
smcowboy1974 smcowboy1974 is offline
Default 1949 Case VAC/ Autolite distributor
Looking to buy a good used autolite distributor for the above model tractor! Must have no play in shaft at any point! Email water@waupacaonline.net if you know of or have access to one of these! Thanks to all who respond
1949 Massey Harris 21A Combine and 1949 B1 Dodge Truck - Classic Tractor Fever casertractor Antique Farm Tractors 0 10-18-2018 01:32:41 PM
1949 Case VAC generator cut-out vs. regulator bigt62097 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 11-19-2013 11:00:27 AM
Autolite Starter G Willikers Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 08-11-2013 11:04:27 AM
Which Autolite plug to use? Meco3hp Magnetos, Ignition Coils and Spark Plugs 4 03-19-2010 06:03:44 PM
Autolite Starter help? Governer0610 Generators & Electric Motors General Discussion 3 02-28-2010 12:32:00 AM
