1916 1 1\2hp z fairbanks Parts?
this thread has 24 replies and has been viewed 7175 times
Old 07-19-2007, 12:02:00 PM
sawdusttv sawdusttv is offline
Default Re: 1916 1 1\2hp z fairbanks Parts?
[IMG][IMG]100_1160.jpg[/IMG][/IMG]
Old 07-19-2007, 10:09:21 PM
Junkologist's Avatar
Originally Posted by KidDynamo View Post
That serial number falls into what I thought would be the early range but the ignitor isn't what I'd expect. It doesn't look like my early one with the mandatory jumper wire.
The trip rod appears to be old style though.
That ignitor is not the same as my late ignitor. I can see the piece with the clamp screw that mounts on the ignitor shaft. It also does not have the conical spring on the outside end of the shaft.
Mike
SmokStak member #146
Old 07-19-2007, 10:13:43 PM
Originally Posted by sawdusttv View Post
OK guys,
I got some pictures, now if I can only figure out how to post them.
Also I was mistaken about the serial # it is 889*** which I believe is a 1947 model, with head no sparkplug.
That serial number does check out to be 1947, but I find it hard to believe that Fairbanks Morse was building an ignitor fired engine at that date. Every engine I have seen of that vintage was spark plug fired and used a Fairbanks Morse FMJ magneto.
Mike
Old 07-19-2007, 11:38:34 PM
Jonathan Widelo's Avatar
Junkologist,
Your right about your engine having a different igniter. Fairbanks used 2 styles for the 1 1/2 hp Headless a 1 spring igniter ( Early Engines 1915 & 1916 Like my engine ) and 2 Spring igniter ( Late Engines 1917& 1918, I know some one who also has a 1919 one too) Is it possible that this engine has a 1 1/2 Plug Oscillator head on it? If so I will trade a good (correct head) head for that head.
sawdusttv your picture did not come through
~ Jonathan
Old 07-20-2007, 10:36:52 AM
Guys I have the pics stoed on my cumputer and on disc but for the life of me, I have tried for two days to post them with no luck. I guess I am just a hopeless computer dumbie.
1916 Fairbanks Morse 3HP JF671 YouTube Old Iron Videos 3 10-31-2016 01:55:33 PM
1916 Fairbanks Morse 3HP Magneto I.D. Steampro Magnetos, Ignition Coils and Spark Plugs 3 01-21-2016 10:03:42 PM
1916 Fairbanks Z 3HP 1916Z3 YouTube Old Iron Videos 2 11-06-2011 08:48:09 AM
1916 Fairbanks Morse 6hp video Petey100 Hit & Miss Gas Engine Discussion 2 11-17-2008 01:33:48 AM
1916 Fairbanks Z, canon type Larry K Hit & Miss Gas Engine Discussion 7 06-08-2007 11:09:24 PM
