'89 Suzuki OHV 4-stroke single?
this thread has 3 replies and has been viewed 2825 times
Old 08-14-2007, 10:17:38 AM
ShortLid ShortLid is offline
Question '89 Suzuki OHV 4-stroke single?
My brother has a 1989 Toro model #26622 witha Suzuki OHV 4-stroke single, air cooled on it. The carb is leaking bad everywhere. Tried cleaning three times and replacing bowl gasket? Could float be stuck? Who made these carbs Mikini? Are there rebuild kits?
Old 08-14-2007, 02:46:34 PM
Sky
Default Re: '89 Suzuki OHV 4-stroke single?
Im not fermiliar myself, with those engines but there are carb. kits available. you'd have to go to a mower dealer/repair shop that deals in toro to get the carb.kit. you have to show them the engine numbers and it probably wouldnt be a bad idea to bring the carburator with you that way they can physically SEE the carburator and make sure you get the correct kit. the leaky carb sound's like the needle isn't seating properly, eaither that or a sticky or incorrect setting of the float.
Old 08-14-2007, 09:56:12 PM
What will need to be done to fix this a complete rebuild or just a good clean?
Old 08-14-2007, 10:06:22 PM
Sky
I would do both if it were me. spray out every little passage and little jet you can find with a can of B-12 chemtool carb cleaner, let that dry out, then put the rebuild kit in it. make sure your float is set level aswell.
Single cylinder 2 stroke marine engine possible ID Scotty 2 Smokstak Down Under 29 03-17-2019 11:06:12 PM
Suzuki SE1800AD Generator Issues doctle odd Honda, Yamaha, Kawasaki, Isuszu Generators 17 04-28-2018 06:39:13 AM
Suzuki SE3000AD AVR help. dacflyer Honda, Yamaha, Kawasaki, Isuszu Generators 15 04-16-2016 02:31:43 PM
Single cylinder four stroke valve setting Gene Fisher Hit & Miss Gas Engine Discussion 3 01-08-2007 08:07:54 PM
Suzuki SE300 John Rolli Generators & Electric Motors General Discussion 0 09-08-2002 02:35:02 AM
