FMZ 2 hp fuel check valve
this thread has 0 replies and has been viewed 1744 times
Old 11-25-2001, 12:01:52 PM
Dale
Default FMZ 2 hp fuel check valve
Hi,I changed the check valve in my Z dishpan competion model gas engine.Its the one with no needle valve and battery and coil operated.I replaced the check valve as i had to take the old one off to replace the fuel cap.It is the new kind of check valve available from a good hydralic hose and valve place here in the city.It has a little adjustment screw on the bottom to adjust the flow.My problem is i replaced this with the new valve and when i crank it i get all kinds of gas coming from around the piston and out through the carb air intake hole.It will not start and the whole garage smells like gas.It does fire once and awhile and the puff of smoke is white.I was wondering if i have to close the little screw on the bottom of the check valve in more to let less gas through since there is no needle valve on this engine to adjust the flow???Has anyone else ran into this problem and or use this type of modern check valve????Thanks Dale
Fuel Check Valve...build or buy? Bevan Everett Hit & Miss Gas Engine Discussion 7 04-24-2019 09:34:13 AM
Associated 2 1/2hp inline fuel check valve gottoolz Carburetors, Mixers, Fuel Pumps and fuel delivery 2 11-23-2018 06:24:10 PM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
IHC LA fuel line check valve wydiver Hit & Miss Gas Engine Discussion 3 11-04-2010 09:07:20 AM
Fuel, check valve problems Dustin D Ehli Hit & Miss Gas Engine Discussion 20 03-27-2007 11:03:51 AM
