1949 B John Deere with Magneto
this thread has 10 replies and has been viewed 7347 times
Old 07-08-2008, 12:57:41 PM
MavGirl
Default 1949 B John Deere with Magneto
Howdy- This is my first post. I have a friend who purchased a 1949 JD and I am curious even though I am a female. So...it seems to me that he should be able to install another magneto but does not seem willing to tackle the project but I have no fear and I would attempt to if I could get some detailed information as to what it takes. Any kind soul out there that could share with me some information about the magneto and other options of replacement and why or why not you should stay with the magneto? Thanks so much....
Old 07-08-2008, 01:39:52 PM
CODY K's Avatar
CODY K CODY K is offline
Default Re: 1949 B John Deere with Magneto
hi i have a 1944 jd b and it takes a wico type c magneto, and when you put it on thier is 2 marks on the flywheel one should say exhaust opes and the other it lh impulse i think and you have to line the right one up with the other mark next to the flywheel to time it right and before the mag is put on it has to be turned to the impulse let me know if you need more help i can dig my book out on it and give you more info cody
The Following User Says Thank You to CODY K For This Post:
Old 07-08-2008, 02:23:34 PM
MavGirl
Cody- Thanks for your quick response. Sounds pretty simple...connecting the dots so to speak? Are there any specific tools that you have to have to install the mag? Do you have an Owners manual? Thanks again!
Old 07-08-2008, 05:02:26 PM
Ray Cardoza's Avatar
pretty much connecting or lining up the dots. dont be afraid to jump in and ask questions.
The Following User Says Thank You to Ray Cardoza For This Post:
Old 07-08-2008, 10:54:40 PM
Tom S's Avatar
Tom S Tom S is offline
Unbolt the old one....bolt on the new one..... If it won't start or backfires violently switch the plug wires. Good Luck!
The Following User Says Thank You to Tom S For This Post:
Old 07-09-2008, 02:32:15 AM
CODY K's Avatar
no special tools needes just a 9/16 open end wrench, yopu have to turn the flywheel and line up the marks that say exhaust open then turn it and line up the other mark that says lh impulse which means left hand impulse then you have to take the mag and turn the back of it untill it stops holding it right side up then the mag is on the impulse then bolt it on its pretty simple and i do have a manual somewhere if you have any trouble i will dig the manual out for you
Old 07-09-2008, 08:45:47 AM
MavGirl
Thanks guys- you are all swell---helping out the damsel in distress- I am technically a city girl now but as the saying goes- you can take the girl out of the country but you can't take the country out of the girl-- I think guys with tractors and etc are awesome-Enjoy your day!
Old 07-09-2008, 09:27:07 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
The lh impulse mark will line up on the compression and exhaust stroke. Remove the spark plug, make sure the piston's coming up on compression when lining up the timing marks.
J.I.M.
The Following User Says Thank You to John in Maryland For This Post:
Old 07-09-2008, 09:30:43 PM
Here's a link for timing/installing the mag.
http://www.retiredtractors.com/Q/Timing.html
J.I.M.
Old 07-10-2008, 10:26:55 AM
MavGirl
What a great resource! You are great! Thanks.
Old 07-10-2008, 10:50:37 AM
Ken Majeski's Avatar
Yup.... Tom is absolutely Correct... As long as the slot in the mag coupling is Horizontal like it should be when the Flywheel says LH Impulse you can just stick the mag on and if it don't start just change the wires.... Can't go wrong on a 2 Cylinder John Deere...
Also there were Some Wico Distributors used on the later John Deere Tractors that Looked almost Like a Wico Mag But were Not a Mag but a distributor... If the Mag seems to be Too Light... It might not be....
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
John Deere Magneto Tony Kimmell Hit & Miss Gas Engine Discussion 8 09-25-2007 10:55:48 PM
John Deere E magneto Tom S Hit & Miss Gas Engine Discussion 4 05-19-2007 09:33:28 AM
John Deere B magneto Robbo Antique Farm Tractors 2 05-20-2006 05:28:02 AM
John Deere Magneto Larry Kastens Antique Engine Archives 5 04-06-2002 09:36:45 PM
Magneto for 1 1/2 John Deere Michael Schweikert Antique Engine Archives 1 09-17-1999 03:18:11 AM
