1935 John Deere D
this thread has 7 replies and has been viewed 3046 times
Old 09-29-2008, 10:38:24 AM
JDD JDD is offline
Question 1935 John Deere D
I just purchased a 1935 John Deere D. I was told that the original magneto was a Dixie. Does anyone if that is correct? If so, anyone have one? Thanks for any help you can give!
Old 09-29-2008, 02:02:53 PM
Forrest A's Avatar
Default Re: 1935 John Deere D
Refer to the D registry published by the two cylinder club from Iowa for what your tractor left the factory with...
Or; Check this out:
http://www.mainelymagnetos.com/JDMagApp.html
What every you do, check the mounting holes for cracks when buying a mag for this tractor, they liked to crack.
I'd suggest using a Wico C base mount in the meantime, they are cheap and parts are available. They will stand getting wet better than the Dixie Splitdorfs.
Forrest A
The Following User Says Thank You to Forrest A For This Post:
Old 09-29-2008, 04:57:46 PM
bocephus_k6 bocephus_k6 is offline
AMEN..!!
We use a Fairbanks I believe on our 36 D and it works very well, we have the original Splitdorf 246T mag for it, but the fairbanks is a far better magneto, and so is the Wico.
Regards,.
Brian
The Following User Says Thank You to bocephus_k6 For This Post:
Old 09-30-2008, 09:47:03 PM
ssimntih's Avatar
ssimntih ssimntih is offline
mind if i ask the serial # of your d? i also own a '35 d, except mine is a "model year". there were drastic changes between '34 and '35, my serial is 119408, making it the 308th tractor off the line in '35, also making it a mutt, it has all the new changes and amenities for '35, but with alot of basic parts like major castings with 1934 part numbers and dates.
i really wanted to ask if you still had the timing lever beside the throttle lever? this is a dead giveaway of the splitdorf type mag used on quite a few of the D's. as you see with the part number break yours should have been equipped with a 246T. mine was originally equipped with a splitdorf, thus my timing lever remains. now im using a wico model C, these are fairly easy to find and parts are readily available and fairly cheap, if you end up with one of these i almost insist you install a new rotor and cap, and set the points. these mags seem to work very well except when used with old parts, then they become very weak very quickly.
Old 10-02-2008, 06:15:52 PM
JDD JDD is offline
The serial# is 122383.
Old 10-06-2008, 06:28:55 PM
ssimntih's Avatar
dont spose you have any pics?
Old 10-09-2008, 10:03:42 AM
K D Redd K D Redd is offline
Speaking of Mags getting wet, I have had good luck sealing old porous mag caps on any brand magneto with clear acrylic top coat paint.
Kent
Or; Check this out:
Forrest A
Old 10-15-2008, 12:53:45 PM
JDD JDD is offline
I have one picture of the tractor but I'm not sure how to post it.
1935 John Deere D ssimntih Antique Farm Tractors 90 08-14-2009 01:27:10 PM
3 hp john deere Dave Thompson Hit & Miss Gas Engine Discussion 3 11-10-2007 10:53:01 PM
6 hp john deere dick c Hit & Miss Gas Engine Discussion 1 08-12-2007 07:17:12 AM
1935 A John Deere Tom S Antique Farm Tractors 1 05-16-2005 12:18:42 AM
JOHN DEERE 3.0 EP TREVOR BRASHIER Antique Engine Archives 0 05-02-2004 04:14:48 AM
