12V to 6V stepdowns
this thread has 5 replies and has been viewed 4090 times
Old 01-31-2009, 12:52:03 AM
Walt Roys Walt Roys is offline
In Memory OF
Default 12V to 6V stepdowns
Ok, I get it. It looks like it is better to run these old igniters on 6V. Where can you get a risister to step 12V down to 6V. I built this nice inition box which contains a garden tractor battery and it all fits nicely. I would like to use that set up with the new primary coil I've ordered. Is there a way , and a resister available that will do that?
Old 01-31-2009, 01:05:50 AM
trudsmtuner trudsmtuner is offline
Default Re: 12V to 6V stepdowns
Go to your local automotive store. and ask for a resistor for an old mopar
car they come in different resistance. they are ceramic with internal resistor. might have to run two to get 6 volts.
The Following User Says Thank You to trudsmtuner For This Post:
Old 01-31-2009, 01:41:58 AM
John Delbert Hidy John Delbert Hidy is offline
Email NOT Working
What you want is a ballast resistor. Tell auto parts store for a 1980 dodge van . john in missouri
The Following User Says Thank You to John Delbert Hidy For This Post:
Old 01-31-2009, 01:46:01 AM
Email NOT Working
It may cut it down to 3 volts
Old 01-31-2009, 01:36:36 PM
Elden DuRand's Avatar
Walt:
What I do is just hook a 12 volt brake light bulb in series with the battery and coil. It doubles as an indicator to tell you that the ignitor is working.
I use it all the time on my F-M Jack of All Trades with the original coil and a 12 volt gel-cell.
Take care - Elden
Old 02-02-2009, 01:39:04 AM
In Memory OF
Thanks , Elden. I knew some one out there had a simple solution. What a great idea to indicate the igniter is working.
Walt
