Simple 2 Axis DRO?
this thread has 11 replies and has been viewed 4373 times
Old 06-10-2009, 08:46:59 PM
Rex Piekarczyk's Avatar
Rex Piekarczyk Rex Piekarczyk is offline
Question Simple 2 Axis DRO?
Just got this mill and would like to put a simple 2 axis DRO on it, but don't need all the features of the $700 to $1500 units I'm finding. All I need is the X and Y position indications to .0005". Anybody know of a setup like that?
Old 06-11-2009, 06:52:23 AM
ListerDiesel's Avatar
Default Re: Simple 2 Axis DRO?
You might find something on Fleabay that fits your needs, we have a 2-axis on the Beaver turret mill, simple and sweet.
As the markets want 3-axis now, the older stuff should be $200 or so for a complete secondhand setup.
Peter
The Following User Says Thank You to ListerDiesel For This Post:
Old 06-11-2009, 06:58:14 AM
Doug Kimball's Avatar
Rex,
A couple of links:
http://www.dropros.com/?gclid=CPffzY...FeFM5QodUBRGeA
http://www.star-techno.com/index.htm
The Following User Says Thank You to Doug Kimball For This Post:
Old 06-11-2009, 08:27:58 PM
Originally Posted by ListerDiesel View Post
As the markets want 3-axis now....
Peter
I'll have the Z axis with one of those add on scales with the integral display.
Old 06-11-2009, 08:32:58 PM
Thumbs up Re: Simple 2 Axis DRO?
Doug-
Thanks for the links. I'll be spending some time with that first one.
Old 06-06-2017, 02:15:34 PM
Originally Posted by Doug Kimball View Post
I've read a few threads on practicalmachinist, but curious to know what the 'Stak community might think .. Anyone out there using DRO Pros more recent EL300/400/700 systems? Looking at one of these 4-axis wonders for a 1968 Bridgeport 2J (12"x30"; 16" knee + 5" quill). For our shop at work - someone else's $$$ (but not much of it).
http://www.dropros.com/Electronica_M...xis_Mill_Kits:
Old 06-07-2017, 12:15:04 PM
John Newman, Jr.'s Avatar
I acquired a 2 axis Accurite DRO very cheap some years back that had bad sending units (table slide encoders) Can those be found for a reasonable price? Would love to add it to my Bridgeport.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 06-09-2017, 06:47:56 AM
John,
I damaged the Accurite Y-axis encoder on my B'port. I Googled a couple of repair places but they only repaired electrical damage or failure, nothing mechanical(my glass scale was broken & a small aluminum casting also broken). I bought a replacement scale which was not the same(higher resolution) but compatible with my system ..... mounting had to be modified. It was around $400 with a new armored cable. Not sure that was reasonable but I've come to rely on the DRO on an old machine.
In Kennebunk, Maine;
Doug Kimball
Old 06-09-2017, 10:14:45 AM
Bubbles Bubbles is offline
We only use Mitutoyo DRO's, with tools you get what you pay for generally.
I remember an old guy telling me "you have to be rich man to buy cheap tools and replace them when they break."
Old 06-09-2017, 11:16:05 AM
I was considering the 4-axis EL700, but for the same price I went with a basic readout EL300 12x30x6 for the mill AND an EL300 8x40 for the lathe.. I didn't want clunky tracks and cable on the head unit, so I'll eventually get a Mitutoyo 6" kit for the quill..
DRO Pros are good people to work with, and I was sold on these magnetic tracks.. IP67 sealed with a 6-year warranty. Time will tell, though. My shop supports the physics and chemistry departments at a small University, so we aren't full-time machinists by a longshot... We take the hand-me-downs from the Mechanical Engneering shop whenever we can
As far as replacements parts - give these guys a call because I think there's at least some compatibility among some types of encoder output signals.. cables and connectors are a different story.
The Following User Says Thank You to gnucklehead For This Post:
Old 06-10-2017, 10:00:21 AM
I found this thread a little confusing since it started in 2009 but has been revived just recently.
But here goes:
Regarding "someone else's $$$ (but not much of it)":
If money IS an issue:
I put a Shooting Star (now Startechno) 2 axis DRO on my old US Machine Tool 8 X 36 vertical mill at least 15 years ago and it has worked without any problems at all ever since. Its resolution is 1/2 thou.
Pete Stanaitis
Old 06-20-2017, 07:56:54 AM
Reeves13hp's Avatar
Reeves13hp Reeves13hp is offline
I bought my Newall from industry recycles on eBay for like $750. Brand new and works great.
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
20-75 Nichols & Shepard
20hp Corner Bracket Advance
16hp Minneapolis
A simple solution..... Brian Lynch Hit & Miss Gas Engine Discussion 12 05-27-2008 08:57:31 PM
Please keep it simple (IHC M Ignition) lister d Hit & Miss Gas Engine Discussion 1 03-06-2008 07:45:13 PM
Simple Gas Engine tjohnson Hit & Miss Gas Engine Discussion 6 08-26-2007 07:35:04 AM
Simple question, maybe a simple answer? Jaeger Don C. Wiley Antique Engine Archives 6 04-05-2004 11:00:08 AM
simple green Byron Roberts Antique Engine Archives 4 02-18-2004 12:11:57 AM
