Catastrophic Failure
this thread has 28 replies and has been viewed 5630 times
Old 09-09-2009, 09:33:24 PM
Doug Kimball's Avatar
Default Catastrophic Failure
A local father and 10 year son bought their first engine at the end of July. The son had saved his money & bought a hit & miss Fairbanks-Morse 2 hp dishpan. They have built a nice oak skid, changed governor springs, renewed valve springs, check valve etc. They've been getting it ready for their first show the weekend after next. Tonight they filled the grease cups & ran it for a few minutes. The cap on the non-locking rod bearing cup came loose, bounced up in the air & landed between cam gear & white metal governor bracket .... THE END for bracket although gears & all steel & iron parts survived. I offered to loan my governor assembly but it has the angle cut gears ... theirs are straight cut. My bracket is cast iron which is probably preferred.
I also offered to loan an engine for the show but the son turned me down although he said he'd help me run mine if he can't get his running. See their ad on EnginAds. HELP!!!
Name:	IMG_0947 (Small).JPG
ID:	62580   Click image for larger version
Name:	IMG_0948 (Small).JPG
The Following 7 Users Say Thank You to Doug Kimball For This Post:
Old 09-09-2009, 09:37:14 PM
Junkologist's Avatar
Default Re: Catastrophic Failure
That's a tough way to start out. I wish I had the parts to send to them.
Mike
SmokStak member #146
The Following 4 Users Say Thank You to Junkologist For This Post:
Old 09-09-2009, 09:51:54 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
question did they use lock tight blue if not you might wanna teach them that secrets of safe engines. I dont wanna see that happen again with anyone. Send them my regards. Atleast we all have our cloudy days.
The Following User Says Thank You to ehpower2 For This Post:
Old 09-09-2009, 10:02:03 PM
eh,
Can't use Loc-Tite on the grease cup cap .... you've got to be able to turn it. Should have been a locking cap .... but OH Well .... lesson learned.
Old 09-09-2009, 10:03:18 PM
ehpower2's Avatar
oh lol i was thinking of the rod cap not the grease cup so sorry i mis read. Wow a small engine tech like me mis reading go figure.
Old 09-09-2009, 11:05:58 PM
vern0n's Avatar
vern0n vern0n is offline
What a shame. That's the kind of thing that will make a grown man cry. That part is real hard to come by. I think Hit N Miss might have them.
The Following 2 Users Say Thank You to vern0n For This Post:
Old 09-09-2009, 11:27:22 PM
Red face Re: Catastrophic Failure
Check with H&M. They should have the bracket and a replacement grease cup. Chances are that the grease cap was either cross threaded or not on enough to hold properly, or the threads were badly worn. When filling grease caps, they MUST be turned down so NO THREADS are showing on the grease cup base, below the cap edge (at least 3/8" of engagement). In all the 50 years of running H&M engines, I have never thrown a properly installed cap. Sorry to hear of the mishap. Hopefully replacements can be had soon.
Better that they had the zinc bracket! If they had the cast iron one, big time major damage could have been done (bent crank, broken cam and or cam gear, busted governor etc) The zinc took all the pressure and saved all else.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 09-10-2009, 01:23:50 AM
Ironman Ironman is offline
Hit & Miss does, indeed, have reproduction governor brackets for the 1 1/2 and 2 HP Fairbanks Z engines. A little steep at 150 bucks for the bare bracket, but the original pot metal ones had chronic problems and it's tough to find a good one...
The Following 2 Users Say Thank You to Ironman For This Post:
Old 09-10-2009, 10:31:04 AM
Elden DuRand's Avatar
If I'm replacing a grease cup for a connecting rod, if it doesn't have an internal spring, I add one.
The spring should fit snugly into the cap of the grease cup and taper so it can bear on the base of the cup. This keeps a little drag on the threads so the cap won't work loose.
Take care - Elden
http://www.oldengine.org/members/durand/
The Following 4 Users Say Thank You to Elden DuRand For This Post:
Old 09-10-2009, 03:02:13 PM
hottube's Avatar
hottube hottube is offline
Similar thing happen to me over 25 years ago with a Fairbanks Dishpan. Gear teeth marks are still on the shed wall today. Fortunately no one was struck by
flying governor pieces.
Name:	shop wall 002a.jpg
ID:	62631   Click image for larger version
Name:	shop wall 003a.jpg
The Following 3 Users Say Thank You to hottube For This Post:
Old 09-10-2009, 04:34:00 PM
Jonathan Widelo's Avatar
I purchased one of those brackets from Hit and Miss a few years ago, for a project 2 HP engine. It is a very well made item, worth the money.
~ Jonathan
The Following User Says Thank You to Jonathan Widelo For This Post:
Old 09-10-2009, 06:59:10 PM
They will look for parts or a parts engine at Dublin .... order one from Hit & Miss on Monday A.M. if not found.
Old 09-10-2009, 08:55:47 PM
Clark Bigger Clark Bigger is offline
are the ones from h&m cast iron?
Old 09-10-2009, 09:36:21 PM
They are aluminum, and look exactly like the originals.
Old 09-10-2009, 10:54:11 PM
Sky
I've got an aluminum repop from H&M my self. YES, a little pricey but sure as hell beats the pants off of that pot metal crap.
Old 09-11-2009, 09:31:57 AM
Russell M's Avatar
Russell M Russell M is offline
Take care - Elden
I don't think my engines have these springs. Where do you get them?
Old 09-12-2009, 03:02:42 AM
IronCity2006's Avatar
IronCity2006 IronCity2006 is offline
Location: Hoopeston, Illinois (90 miles south of Chicago)
anyone have a good casting they can spare for a pattern? I can cast it no charge for the castings, this is sad, I know their feeling
The Following 5 Users Say Thank You to IronCity2006 For This Post:
Old 09-14-2009, 07:27:36 AM
Talking Re: Catastrophic Failure
Father & son came to Dublin, NH show last Saturday. Found no dishpan parts for sale. A few complete engines for sale between $400 & $600.
A few hours after they left I found a nearly complete(missing mag & gas tank) throttler with cast iron governor bracket & angle cut gears. I purchased it for them & delivered Sunday. The plan is to replace angle cut gears with their straight & get the hit & miss engine running for this coming weekend at the Trolley Museum. This winter they will try to find a bracket and maybe a mag & get the throttler running also.
Within minutes of delivery the son had oiled all bearings & cylinder & was starting to get decent compression with good "bounce-back".
Bad news is that they are still looking for a reasonably priced bracket .... good news is they now have two engines and are having fun!!
The Following 14 Users Say Thank You to Doug Kimball For This Post:
Old 09-14-2009, 08:30:32 AM
John Savot John Savot is offline
Good show Doug! You really did it though - getting them a parts engine that turns into a keeper. Is there any end now?
John
The Following User Says Thank You to John Savot For This Post:
Old 09-14-2009, 11:04:07 PM
Smile Re: Catastrophic Failure
"Is there any end now?"
John,
I hope not. They seem to be a real nice family and are having fun. They aren't afraid of getting dirty & try to do things on their own. When they run into a snag they're not afraid to ask for help and I certainly don't mind helping them.
Father & grandfather came tonight with broken white metal bracket & camshaft stuck in cam gear. Cams for hit & miss engine & throttler have different profiles so the one from damaged white metal bracket will be re-used in cast iron bracket. They had already removed camshaft from 'new' cast iron bracket & gear with little trouble using a gear puller. This one from original failure was really stuck in cam gear .... did not want to damage the gear.... gear puller unsucessful , tie rod wedge unsucessful, small amount of heat unsucessful, much heat, bucket of water, & arbor press removed it after "heat treatment" very easily without damage.
They will start reassemby tomorrow evening.
The Following 2 Users Say Thank You to Doug Kimball For This Post:
Kohler Generator Voltage REgulator Failure James Hollifield Kohler Generators 1 06-30-2006 01:35:28 PM
New page up - failure to reciprocate kerogas Hit & Miss Gas Engine Discussion 19 03-18-2005 11:10:16 AM
