Installing a fly wheel key
this thread has 13 replies and has been viewed 1768 times
Old 09-12-2009, 05:29:05 PM
Rag
Default Installing a fly wheel key
I'm installing the key on 1 1/2 hp fly wheel. The fly wheel hub is at least 3 inches deep. The old key, and a new one I bought, only goes in an inch even with tapping.
How should they be installed? Do you file and fit them to penetrate at least 2 inches? Pure pounding seems like a bad way to go.
Old 09-12-2009, 05:51:54 PM
Byron Roberts's Avatar
Byron Roberts Byron Roberts is offline
Default Re: Installing a fly wheel key
So if the old key only went in about 1" ..i would say it was installed wrong..i would think if it was shaped to size of end of key that fits..it should be good..to big of taper will not be good..and pounding in will not help in a long run..B,
Old 09-12-2009, 06:10:47 PM
Rag
So, you say I should file/sand to get good penetration and a bit of wedging at the end?
Old 09-12-2009, 06:33:56 PM
Yea..I agree the more you can get fit into the hub the better..Maybe someone more knolagable(sp) than me knows ..I don't remember the keyway ever on a flywheel being cut at a taper...B,
Old 09-12-2009, 09:30:28 PM
You can't get the riht answer to your question until you tell the brand of engine you have . If the engine has a split hub with bolts spanning the split use a straight square key. spread the hub slightly with a chisel. Then drive the key in. THEN tighten the bolts. If the flywheel have no split in the hub it takes a tapered Gib key driven in until ti is securely driven in. Give us little more info. Good luck in a good hobby Joe Morris
The Following User Says Thank You to Joe Morris For This Post:
Old 09-12-2009, 11:33:57 PM
If it's a gibb key you need to fit it. I use a pemanent marker, but you are supposed to use bluing. I mark the key, slide it in and remove it, file the high spot. It should go all of the way nearly through the flywheel if fitted correctly, should not bottom out angainst the flywheel on the outside, or the crank or gear on the inside, try to get maximum contact with the flywheel.
Old 09-13-2009, 01:46:49 AM
Many old engines used non-standard keys and keyways.
In those cases you HAVE to do the best you can with what you have.
If you have a large enough grinding wheel the side of the wheel can be very handy for removing material from the key more evenly than across the face of the wheel.
Old 09-13-2009, 05:26:22 AM
Neale Behm's Avatar
Neale Behm Neale Behm is offline
A belt sander works quite well too!
Old 09-13-2009, 10:17:18 AM
Rag
Thanks guys. It's a 1 1/2 hp IHC-M using a gib key. That is, it has a raised end, but if tapered, very slight.
I'll try fitting with file and sand paper.
Old 09-13-2009, 11:32:36 AM
Dave Rhoades Dave Rhoades is offline
I use a candle to blacken the key then draw file the shinny areas.
Old 09-14-2009, 09:02:55 AM
Rag
Got it fitted with marker and file. Thanks
Old 09-14-2009, 10:53:17 PM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
Good job. The taper on a gib key is 1/8th inch per foot.Rag I just bought a McCormick Deering 1 1/2 hp with WICO mag.It ran all weekend at Penns Cave.Dick
Old 09-14-2009, 11:32:27 PM
1/8" per foot is the standard........but LOTS of 'em aren't standard.......
Old 09-15-2009, 11:09:22 PM
Rag
I wish I had made it up there to say hi, Dick.
Would like to have seen the M.
Installing a Model M Gib key... FireChief811 Hit & Miss Gas Engine Discussion 3 07-31-2008 08:43:24 PM
Installing staybolt steamer86 Steam Stationary Engines, Traction Engines 8 02-02-2008 12:25:23 PM
Installing oil filter on BFA 4.0 flynfol Onan Generators 0 05-28-2007 09:56:07 AM
Installing the Piston in an FM-Z 3HP Harry Hit & Miss Gas Engine Discussion 3 05-26-2007 11:15:49 PM
Installing handholes Rick Strobel Steam Stationary Engines, Traction Engines 24 12-07-2005 12:14:36 PM
