What Coil and Battery ?
this thread has 9 replies and has been viewed 2073 times
Old 09-15-2009, 07:34:21 AM
Dave H Dave H is offline
Default What Coil and Battery ?
So I got the 3hp Majestic all cleaned up and ready to go, what coil and battery do I need to use on it ?
Can I use the 6 volt coils they sell at Starbolts and a regular 6 volt battery ? Also, what gauge wire is the best to connect them ?
Old 09-15-2009, 08:55:27 AM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
Default Re: What Coil and Battery ?
You can buy low tension coils from Startbolt or Hit & Miss. You can also a car coil, fluorescent light ballast etc. or wind your own. Here are a couple of examples. http://engines.rustyiron.com/ltcoil/index.html or
http://www.geocities.com/flywheels20...nsioncoil.html
I run mine on twelve volts six volts works fine as well.
J.I.M.
The Following User Says Thank You to John in Maryland For This Post:
Old 09-15-2009, 10:21:35 AM
Exclamation Re: What Coil and Battery ?
10 0r 12 guage single strand wire is best, not multistrand. make sure your contact area is clean and shiny.
Old 09-15-2009, 12:43:18 PM
Thanks Guys, just ordered the 6v coil at Starbolts. Now I need a battery and some wire.
Old 09-15-2009, 03:48:34 PM
Dale Russell Dale Russell is online now
Dave, If you have a Handicapped business that sells Power chairs, Check with them and see if they will trade a dead battery for one that they have taken out of a chair. Lots of times the batteries that they take out will check out good and hold a charge. I get 35 AMPH batterys all the time which are Gell Cells [Sealed] that I run my engines on with no problem. My 2cents, Dale
Old 09-15-2009, 08:06:15 PM
Tom Martin Tom Martin is offline
Andrew, why do you think single strand wire is better than multi-strand? Single strand is much more liable to break due to vibration which is why you see the wire coild on old engines in pictures. I have always used multi-strand and never had a problem of any sort.
Old 09-15-2009, 09:14:45 PM
Mike Monnier's Avatar
Hoarder
Dale's suggestion is good for cheap batteries. Another idea is that this is the time of year that places like TSC, Cabela's, Bass Pro, etc. stock gel cell batteries for use in deer feeders and game cameras. Typically you can buy the 6V batteries with either spring or spade tops for not much more than a decent lantern battery. They also sell trickle chargers fairly reasonable to top off the charge after a show. If you're into the whole "green" thing, solar chargers are also available to keep your iron addiction off the grid.
Old 09-16-2009, 09:24:24 PM
George Womack George Womack is offline
Originally Posted by John in Maryland View Post
...You can also a car coil...
I was just on the verge of asking about this for my Fairbanks headless Z which is missing the magneto. Do you just use the primary side of a regular automotive coil?
Old 09-16-2009, 10:32:05 PM
Kevin Pate Kevin Pate is offline
Yes, you only use the primary side of the car coil if it is an ignitor setup..
Old 09-17-2009, 09:52:31 PM
6hpMarty 6hpMarty is offline
I have been using a 6volt lantern battery and a Ford coil, been running about 20 hours and still going
Coil and Battery Question Dennis Hit & Miss Gas Engine Discussion 1 05-08-2005 10:20:08 PM
Battery and Coil Questions ellinw02 Antique Engine Archives 8 06-23-2004 09:57:29 AM
Battery and coil Dave Ho Antique Engine Archives 7 10-27-2002 02:57:48 AM
Re: Coil and Battery Russ Hughes Antique Engine Archives 0 12-19-2000 05:52:18 AM
Battery & Coil Boxes Bob Naske Antique Engine Archives 1 11-26-2000 12:17:21 PM
