1923 Witte Model B Carburetor Removal?
this thread has 6 replies and has been viewed 1573 times
Old 09-16-2009, 06:12:21 PM
NAMPeters
Question 1923 Witte Model B Carburetor Removal?
The carb is thread (pipe thread?) mounted to the cylinder head and needs to be removed to repair the head. In order to do no harm are there any tricks and/or special tools needed?
Old 09-16-2009, 08:06:17 PM
Default Re: 1923 Witte Model B Carburetor Removal?
I've gotten 2 or 3 of them apart. It's not easy. You need a big bench vise and a pipe wrench that fits the neck of the carb, next to the threads. Soaking helps but is not the answer. The last one I did, I had to heat all that chrerry red and toss it in a bucket of water. After it cooled, I got it apart. Maybe someone else has a better way, but, that's how I've done it without any adverse affects, I could tell.
Old 09-16-2009, 08:35:39 PM
chattblacksmith chattblacksmith is offline
i just finished doing the same thing today. my trick was a big pipe wrench right next to the head. then clamp it in a vice and heat all around the fiting but try not to heat the fiting it's self. as soon as it starts to turn it should come on out pipe thread is a taper thread so the futher it turns the looser it gets.
good luck chris
Old 09-16-2009, 10:10:44 PM
vern0n's Avatar
vern0n vern0n is offline
I made a tool once for this. I welded a short piece of pipe to the end fo a bar. The pipe was just small enough to fit inside the bore of the mixer. I them welded a tab further up the bar that cought on the resivior of the mixer. This bar was 3 feet long and still would not budge it. I then heated the head red hot. This did the trick. One thing I found out was the butterfly was soldered to the shaft. After heating it up to get it off, the butterfly fell out and I had to fix that.
Old 09-16-2009, 11:01:09 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
I had to remove the carb. on my 1924 2 H.P."B" & I put the head in the vice,took the rosebud & heated The head up good & quick right around where the carb. screws in & put a 24" pipe wrench on it right by the threads. It came right out & relatively easy.
"So Much Iron & So Little Money"
Old 09-17-2009, 10:10:28 AM
NAMPeters
Thumbs up Re: 1923 Witte Model B Carburetor Removal?
Thanks for the inputs. I will be in the shop and give it a shot.
Old 09-18-2009, 09:41:24 PM
NAMPeters
Well here are the results of the carburetor removal:
1. The pipe wrench with extension worked without heat. The wrench left some marks but these are cosmetic and fixable.
2. The head had more of a problem than originally thought. Cheesy weld, epoxy coating and rubber cement layer. Looking for a replacement. Note the head was placed on the engine down side up for photography purposes.
ID:	63231   Click image for larger version
1923 Model TT truck Randy L Peterson Antique Autos and Trucks 1 10-29-2007 09:20:50 PM
1923 Fairbanks Morse Model Z Problem Ratchet88 Hit & Miss Gas Engine Discussion 7 08-19-2006 09:20:03 AM
Kohler Model D Manual, Older (1923-25) Rusty Fingers Kohler Generators 14 11-15-2005 11:58:12 PM
1923 Fairbanks Morse Model Z Problems Ratchet88 Hit & Miss Gas Engine Discussion 17 07-16-2005 10:41:02 AM
1923 Witte Model B 2Hp Engine StephenG Antique Engine Archives 5 01-21-2004 09:10:06 PM
