More Witte QUestions
this thread has 5 replies and has been viewed 1081 times
Old 09-16-2009, 06:50:54 PM
chattblacksmith chattblacksmith is offline
Default More Witte QUestions
I am restoreing a witte model b and have a few questions.
1. I need an exhaust valve so if anyone has on they are willing to part with please let me know. But can i take an automotive valve and bore out the guide hole hole for the steam to clear or do i need to put a bushing in it seeing as how it is a hardened valve?
2. Is the model b a duel fuel engine or if not why is there that extra bowl and needle vlave on the carb? So can someone explain the carb i think i know how it works (it seems simple) but i could be wrong that has happened from time to time.
3. I nneed a mag but dont know what kiand it takes other than that it is a wico judging from the zip lock bag of parts i have that ues to be a mag.
Any help with this engine would be very appricated it is my first hit and miss rebuild and only my third engine rebuild.
Thanks all Chris
Old 09-16-2009, 06:53:23 PM
Default Re: More Witte QUestions
One more thing what is the factory bore size of that motor i might have to resleeve.
Old 09-16-2009, 08:07:57 PM
Chip Watford Chip Watford is offline
Chris,I would probably just order a valve from Hit and Miss if you don't feel comfortable making one.It is a kerosene engine.It uses a WICO EK mag and it is not a hit and miss but a throttle governed engine.Don't know the bore size since you didn't mention the hp. Chip
The Following User Says Thank You to Chip Watford For This Post:
Old 09-16-2009, 10:43:32 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
A Witte Mod."B" can either have a Wico EK or take a battery & buzz coil. They came from the factory either way,so you have to figure out witch way yours is set up.
"So Much Iron & So Little Money"
Old 09-17-2009, 09:29:50 AM
David M. Lyon's Avatar
Here's a clip of my 5 horse "B" with the "EK" magneto set up. It's been a long time since I restored it, but I believe I used valves from a 302 Ford engine and re-sized them. Then I reamed the guides for a good fit...It'll run even slower once it warms up some. I run it on camper fuel.
http://www.youtube.com/watch?v=1IzwrwFaDSA
Old 09-17-2009, 10:02:45 AM
vern0n's Avatar
vern0n vern0n is offline
I used VW air cooled engine, (1600 cc), intake valves in my 2hp Witte B. The stem and the head are the right diameter, just had to cut it to the right lenth. I then drilled the stem and used a cotter pin to retain the spring. You might find a shop with some spare used valves.
Witte gas tank questions Joel Mosley Hit & Miss Gas Engine Discussion 1 06-12-2009 04:52:17 PM
10 HP Witte Engine Questions Tom G Hit & Miss Gas Engine Discussion 6 05-08-2007 04:53:23 AM
Witte 100 RDA rebuild summary & questions Daric J Generators & Electric Motors General Discussion 8 08-01-2005 05:40:50 AM
Witte Dieselectric Questions... Robert Generators & Electric Motors General Discussion 10 02-12-2003 12:42:39 AM
Witte questions.. Tim B Antique Engine Archives 2 03-14-2001 02:05:57 PM
