Goold,Shapley,and Muir Info & Parts
this thread has 7 replies and has been viewed 1806 times
Old 09-17-2009, 06:15:06 PM
Tim M Tim M is offline
Default Goold,Shapley,and Muir Info & Parts
Hello, I need some information and parts for the GSM upright pictured below.It has a ser. # of 2184, the speed and horsepower was left blank on the tag,and has 16" flywheels.I would like to know the year made and the horsepower.Now for the missing parts,it's missing all the gov. components and latch out.I would like to have a picture of this area from a complete engine so I know what I am missing and know what to look for when searching for parts.It is also missing the cover plate on the side.The crank it is bent some what but can be straighten easy enough if I can't find a replacement.It does have the igniter so thats a plus.Any information or leads on parts would be great. Thanks
ID:	63172   Click image for larger version
ID:	63173   Click image for larger version
ID:	63174   Click image for larger version
The Following 2 Users Say Thank You to Tim M For This Post:
Old 09-17-2009, 06:54:10 PM
Default Re: Goold,Shapley,and Muir Info & Parts
Hi tim i think your engine is a 2h.p. as for parts you will have to do some searching i would try on here on engineads if you want to know more on your engine get in touch with denis rouleau he is a member on here and is good with gsm engines.John
Old 09-17-2009, 08:33:55 PM
bocephus_k6 bocephus_k6 is offline
Either Dennis or Owen Bosma, he's a G S M collector with a lot of info and pictures on his website, he too is a member on the Stak.
Brian
The Following 2 Users Say Thank You to bocephus_k6 For This Post:
Old 09-17-2009, 08:49:16 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Hi Tim
Here's the registry Denis Rouleau started. If you look at engine #2292 it's a round hopper like yours and the RPM & HP are left blank. It's in our barn so I'll snap some pics of the governor when I'm out there tomorrow.
Jonathan
The Following User Says Thank You to Sad Iron For This Post:
Old 09-17-2009, 09:32:09 PM
Jim Martin's Avatar
Jim Martin Jim Martin is offline
Tim,,I have an engine I can take close up pictures for you?,,I believe its smaller than your engine,,seems like the flywheels are around 12 inchs?,,Jim
The Following User Says Thank You to Jim Martin For This Post:
Old 09-17-2009, 09:47:12 PM
Sad Iron and Jim, I'm looking for any pictures that might help me figure out what I'm missing.Thanks in advance,Tim
The Following User Says Thank You to Tim M For This Post:
Old 09-18-2009, 08:34:35 AM
Owen Bosma's Avatar
Owen Bosma Owen Bosma is offline
What you have is 1 1/2 hp engine built some time between 1907 and 1914 in 1915 the engine was changed to a sqaure hopper, the parts of the sqaure hopper ara basically the same. I have scanned a parts list for you but the files are to large for the stac. send me your email and I will send them to you direct.
........ Owen http://home.cogeco.ca/~obosma/gooldshapleymuir.html
The Following 2 Users Say Thank You to Owen Bosma For This Post:
Old 09-18-2009, 11:05:16 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
If you have a Goold Shapley & Muir engine I would be interested to get your pictures and add it to the registry here:
http://buzzcoil.brinkster.net/gooldsm/page101.html
Thanks!
Denis Rouleau
Goold, Shapley & Muir Co. Denis Rouleau Hit & Miss Gas Engine Discussion 34 08-20-2009 10:36:29 PM
Goold Shapley & Muir: please help bwakeford Hit & Miss Gas Engine Discussion 3 06-06-2008 08:08:29 PM
INFO: Needed Goold, Shapley and Muir Alex Antique Engine Archives 1 08-31-2003 08:50:32 AM
Help I.D. Goold Shapley Muir David Heggie (qc-cda) Antique Engine Archives 0 05-11-2003 03:32:42 PM
Goold-Shapley-and Muir D.J. Baisch Antique Engine Archives 0 08-04-2002 09:13:48 PM
