Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Mill Creek Central, Ohio
this thread has 3 replies and has been viewed 2305 times
Old 10-27-2009, 08:29:23 PM
jht1057 jht1057 is offline
Default Mill Creek Central, Ohio
Hello all,
Just got back from a weekend trip to Mill Creek Central in Ohio. It is a privately owned 7 1/2" gauge railroad. It was rainy and very cold, but still a good time. The sleeping quarters for some of us was a caboose. Had many chances between rain drops to get some run time in, the railroad has over three miles (yes real miles) of track with a lot more planned for. There were a dozen different steam locomotives alone, plus another half dozen gas or electrics.
Jim
Name:	Mill Creek.jpg
ID:	65824   Click image for larger version
Name:	Mill Creek2.jpg
ID:	65825   Click image for larger version
Name:	Mill Creek3.jpg
ID:	65826   Click image for larger version
Name:	Mill Creek4.jpg
The Following 7 Users Say Thank You to jht1057 For This Post:
Old 10-27-2009, 10:30:25 PM
gbritnell gbritnell is offline
Default Re: Mill Creek Central, Ohio
That trestle looks like quite an investment!!
gbritnell
Old 10-27-2009, 11:17:37 PM
Actually, the materials for the trestle columns and main beams were surplus from a local power plant for just a few hundred dollars. There is still enough pieces on hand to build yet another bridge as large as the current one.
Jim
Name:	Mill Creek5.jpg
ID:	65836   Click image for larger version
Name:	Mill Creek6.jpg
The Following 2 Users Say Thank You to jht1057 For This Post:
Old 10-28-2009, 09:20:36 PM
The tunnel is rather large as well, there are ten, eight foot diameter x 12 foot long gas tanks, set end to end with a radius of about eighty feet. Looking at the terrain above and around the tunnel, it is hard to tell the tunnel is there, let alone that it was all dug up and re-graded. There is another single tank tunnel that goes under the driveway.
Jim
Name:	Mill Creek9.jpg
ID:	65882   Click image for larger version
Name:	Mill Creek7.jpg
ID:	65883   Click image for larger version
Name:	Mill Creek8.jpg
ID:	65884   Click image for larger version
Name:	Mill Creek10.jpg
The Following User Says Thank You to jht1057 For This Post:
The last intact steam tow-boat in Ohio headed to an Ohio Shipyard Farquharman Steam Stationary Engines, Traction Engines 5 10-13-2009 09:21:36 PM
Unidentified Feed Mill, Grist Mill, Grinder Shawn Rogers Farm Antiques and Collectibles 7 09-02-2009 09:49:24 AM
Early Challenge Windmill & Feed Mill Co Mill Steve Barr Farm Antiques and Collectibles 6 08-16-2009 12:14:59 PM
Ohio Engine Co. Sandusky Ohio question Randy Hart Hit & Miss Gas Engine Discussion 8 01-27-2009 05:03:54 PM
grist mill/central louisiana JIM KIRKWOOD Antique Engine Archives 0 08-17-2000 06:00:17 PM
