S.B. Blasting Detonator
this thread has 21 replies and has been viewed 11398 times
Old 12-02-2009, 11:36:57 PM
Dumpster Dumpster is offline
Default S.B. Blasting Detonator
I have an old plunger type blasting detonator as we always saw on the cowboy movies in the 50's. If I place my fingers on the terminals and push the plunger down I think I would get a poke but I feel nothing and a volt meter only slightly moves. Is this similar to a Magnito on a Hit and Miss engine and the insides contain a magnet that must be recharged? There are two coils 2X4" and the circuit is complete. I was told it was made in Lancaster Pa.
Old 12-03-2009, 12:31:50 AM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: S.B. Blasting Detonator
PICTURES PICTURES i have always wanted 2 see what was inside of one of those things
Old 12-03-2009, 12:52:26 AM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is online now
It is most likely not going to generate a high voltage. What kind of mechanism is inside - A gear rack (plunger) driving a pinion gear on the armature? My thought is that it would make low voltage at a fair amperage to heat a fine coil, like a light bulb filament, that sets off the detonator charge. Maybe see it it will light up a bulb from a flashlight???
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-03-2009, 12:54:37 AM
ehpower2's Avatar
well shouldnt it be high voltage because you need to carry the current a really far distance. I think you would need high amps current and voltage so when you have the wires out a 1000 ft you can still detonate the explosives
Old 12-03-2009, 01:09:28 AM
Eric M.'s Avatar
Eric M. Eric M. is offline
My bet is it would be fairly low voltage. High voltages can suffer induction losses over long distances. This is a problem on large industrial engines with long spark plug wires.
Old 12-03-2009, 01:15:45 AM
jht1057 jht1057 is offline
I agree, pictures, pictures, pictures, pleeeeeease.
Jim
Old 12-03-2009, 03:08:27 AM
Eric M.'s Avatar
Aha! Here is the answer.
http://books.google.com/books?id=fuj...onator&f=false
The Following 2 Users Say Thank You to Eric M. For This Post:
Old 12-03-2009, 08:46:07 AM
Tom Martin Tom Martin is offline
The blasting machine contains a magneto similar to a crank telephone magneto. The plunger has a rack which revolves the magneto, and at the bottom of the rack is a switch which closes at the bottom of the stroke to complete the circuit to the blasting caps. Closing the switch at the bottom of the stroke insures that only the peak voltage goes to the caps. There is a rachet arrangement so that the magneto is not rotated on the up stroke of the plunger. Common blasting caps are designed to fire at 1v/1 amp. Blasting machines are usually rated to fire a certain number of caps wired in series 25, 50, or 100 caps. There are detonators that are designed to only fire at much higher voltages, above 2kv where safety is the primary requirement. They are normally fired with a capacitor discharge firing system.
The Following 2 Users Say Thank You to Tom Martin For This Post:
Old 12-03-2009, 06:17:46 PM
PTSideshow PTSideshow is offline
Here you go this is from my copy of the Dupont Blasters handbook.
Enjoy
The Following 3 Users Say Thank You to PTSideshow For This Post:
Old 12-03-2009, 10:10:39 PM
Here are the pictures that some have asked for. Thanks for all the input. This was my first post.
ID:	68443   Click image for larger version
ID:	68444   Click image for larger version
ID:	68445   Click image for larger version
The Following User Says Thank You to Dumpster For This Post:
Old 12-05-2009, 02:00:14 PM
Dave Frost Dave Frost is offline
You need to find some ACME dynamite and have some fun....
Old 02-25-2016, 11:08:06 PM
Duane643 Duane643 is offline
thanks for the pics. i have one that
t the case is rotted clean off and the pics will sure help in the repair
Old 02-26-2016, 01:20:08 PM
Big Bird Big Bird is offline
I always liked those old Detonators for blasting... one of those and some old road flares would make For a cool display at a show.....
Old 02-27-2016, 09:19:00 AM
51cub 51cub is offline
I see the date on this, but it's the first I saw it. Does anybody know what became of this? I'm curious if it ever got cleaned up, or restored, maybe even gives the cat a little motivation
Old 07-07-2018, 12:52:54 AM
M10a3 M10a3 is offline
I have a blasting machine that I think is either a New York or Schneider Brothers number 2. The label plate is missing so it’s hard to tell. It works and is in good shape. Somebody repaired and refinished it. It is about 9 3/4 inches high and 4 1/4 across face and 61/2 deep.
ID:	313798   Click image for larger version
ID:	313799   Click image for larger version
ID:	313800   Click image for larger version
Old 07-07-2018, 01:49:50 AM
Power Power is offline
Can't be very many amps because if you look at a spool of blasting wire, except for special insulation color, it looks like telephone cable wire- about 24 gauge.
Old 07-07-2018, 10:03:08 AM
A blasting cap requires about half of an amp to fire reliably. It’s the length of blasting wire and how many blasting caps you are firing that require higher voltage due to the resistance of said wire. I did a half assed push on the plunger with a fluke attached and I got just over 11 volts. I need to do a proper push to get an accurate reading. I just don’t want to break it the first month I have it.
The Following User Says Thank You to M10a3 For This Post:
Old 07-07-2018, 10:26:47 AM
I would consider opening it up, checking for bad / worn out internals, cleaning and lubing as needed. Then I would feel confident giving handle a proper push.
I have only seen one used once. The farmer gave it a really fast push. For a moment you could hear insides spinning fast, then the blast.
Old 07-07-2018, 01:20:27 PM
Your typical old time telephone crank 'generator' puts out about 45 volts AC at about 1/2 an amp. it will light a few flash light bulbs but no more. I rigged one up to a small steam engine once, and it would light 4 6 volt bulbs pretty brightly, at a good rate of speed.
I suppose, it you spun it fast enough, it would fire a model hit and miss engine. Not sure if it has enough OOOMPH to fire a full size engine though. if you re-wound the armature with heavier wire, it certainly would indeed work.
Old 07-08-2018, 07:00:22 PM
I measured in DC, I would if I should see if it runs in AC, I could have measured the wrong volts. Interesting. I am in the business of blowing things up, so I will be hooking this up to one blasting cap just for old time sake. I’m away now, when I get back home I will do some extra testing with the fluke meter
Soda blasting ? Michael E. McCracken Hit & Miss Gas Engine Discussion 26 12-29-2006 01:32:02 AM
blasting or electrolysis Mike F Hit & Miss Gas Engine Discussion 9 03-16-2006 05:15:22 AM
SAND BLASTING DAVID BABCOCK Paint Shop 1 01-04-2004 10:09:28 PM
Abrasive blasting M.Smith Antique Engine Archives 6 12-25-2003 11:37:48 PM
Sand Blasting Dave Valentine Antique Engine Archives 18 02-05-2002 11:38:16 PM
