1953 B7S 5S 3hp (No Spark)
this thread has 2 replies and has been viewed 1268 times
Old 12-14-2009, 11:46:24 AM
Michael Veach Michael Veach is offline
Default 1953 B7S 5S 3hp (No Spark)
Just got this motor.It has been in a basement for past 30 years. For the most part in good shape. Don't think it was running when it was "retired" It is a one owner. I deglazed the cylinder, rings are good and it has good compression, Carb is cleanable. It has NO spark. Have scuffed, cleaned and set points at .020. cleaned all connections and wire ends and reassembled. NO SPARK. Any help?
Old 12-14-2009, 02:22:28 PM
Ray Cardoza's Avatar
Default Re: 1953 B7S 5S 3hp (No Spark)
Try a new condensor. they go out and you get no spark
Old 12-17-2009, 11:57:13 PM
Exclamation Re: 1953 B7S 5S 3hp (No Spark)
The 5-S is a 11/2 HP engine. Points .020, plug ,025, mag to flywheel in the area of 6 to 8 thousandths (.006-8). After replacing the condenser, re-set all clearances: To set points, turn the crank until points are open the widest (turn the engine thru 360 degrees to check this). Loosen the point mount, set the points to .020, while holding the crank toward the head. Install the points cover and flywheel, then set mag position. To set mag clearance, loosen all 4 core mount bolts, and lift mag away from the flywheel. Hand tighten 2 bolts to hold the core in place. Place a post card under the core, between it and the flywheel. Turn the flywheel until the magnets are under the core, Loosen the bolts, and allow the core to clamp the card between it and the magnets. IMPORTANT LIFT the Flywheel toward the head, and THEN tighten the 4 mount bolts securely. Don't strip 'em! Turn the flywheel, and remove the card. Now test the spark The 5-S should easily provide a 1/4" spark, just turning the engine by hand. Make sure your points meet flush, and are free of debris and oil. After I set points, I use a clean white business card, and place it in the points, close them, and draw it out slightly. The points are then opened, and the card inspected. Smudges and or black traces are debris or oil on the points. Repeat until the card comes out clean!
Questions about 1953 Reo Trimalawn Mower RJAaaaaa Garden Tractors and Mowers 11 05-14-2009 10:10:27 AM
1953 kato gen set 6 cylinder contienental artzmobile Generators & Electric Motors General Discussion 6 03-22-2008 03:52:52 PM
1953 lawnboy mower jcbwls Garden Tractors and Mowers 1 08-27-2007 07:25:46 AM
1953 Federal Fire Truck Richard Grissom Antique Autos and Trucks 8 04-16-2007 09:21:07 AM
1953 Kohler Generator Gene Largent Kohler Generators 8 06-16-2002 08:04:18 PM
