1864 Cub Cadet concern
this thread has 8 replies and has been viewed 5605 times
Old 10-02-2010, 06:05:46 PM
BDMelon BDMelon is offline
Unhappy 1864 Cub Cadet concern
I have a cubcadet 1864, kohler engine 18 hp . oil is coming out the breather hose , that sits inside the air cleaner housing, oil is coming out of it when engine is running so much, it running down getting into the flywheel & throwing it everywhere &( or consume's oil), then mats up the cylinder heads, Can someone tell me WTH is going on here, are the rings done in this engine, or do I have some other concern with the beathers on this Engine
Has 800 hrs on it , Pisses me off my other cub same type of unit, has 1,700 hr & does not have this conern...
Old 10-02-2010, 07:52:22 PM
K D Redd K D Redd is offline
Default Re: 1864 cubcadet concern
I assume the engine is an M-18 Kohler. The first couple of thing to check are: First be sure you have not over filled the engine with oil. Second, Be sure the oil fill hole and dip stick are sealing well so outside air can not enter the crankcase. If both of these check out, your engine likely has to much blow-by and needs rebuilt.
I have done several of the Kohler KT-17's. The main difference in the two engines is the KT-17 are battery ignition and the M-18 is an electronic flywheel magneto. The M-18 has a full flow oiling system with oil filter. Early Kt-17's were NOT full flow oil system. The later Series II KT-17 were full flow oiling systems. Not all Series II were set-up for an oil filter. The last KT-17 I did was for Dad. I took a plain Kt-17 case and converted it to a Series II. When I do a Early KT-17 that is not a full flow system, I drill a couple of extra oiling hole in the rod so they will oil better.
Kent
Old 10-02-2010, 09:00:02 PM
Oil level is perfect & dipstick is in place, I heard that m-18 have some reed valves of some type for crankcase, if these break, will this cause this concern? but where the Heck are these at ? Commander Engine
Old 10-02-2010, 09:52:17 PM
If it is a Commander engine FORGET EVERYTHING I posted. The engine in you CC is a Over Head Valve engine. I have NOT turn a wrench on one of them. I have on an earlier Kohler OHV. If this was a Briggs OHV, I would say you may have a partially blown head gasket the is pressurizing the crankcase causing your oil blowing problem. Briggs had a problem with this.
I do not know how much of a WRENCH you are. You might try holding each cylinder at TDC on the compression stroke. Then pressurize each cylinder with compressed air to see it you have a leak into the crankcase. If you try to do this be sure to firmly hold the crank from turning. DO NOT do this with your hands! you need to bolt it solid some way.
Kent
Old 10-02-2010, 09:55:46 PM
K-Tron K-Tron is offline
I had a very similar problem with my Tecumseh HMSK-80
It turns out that the oil was getting slung everywhere because of two things, the plastic oil slinger gear (with the metal flyweight inserts) needed to be replaced, and the governor was not set right.
Maybe the same is wrong with yours, I am not familiar with the engine you have,
Good luck,
Chris
Old 10-03-2010, 07:38:15 AM
JKWidener's Avatar
JKWidener JKWidener is offline
If it is a twin cylinder, check the compression on both sides of the engine, you will probably find that one side is considerbly lower than the other. The one with the lower compression has a blown head gasket. These command engines were known for this. Replace both head gaskets, not just the one that needs it. Also it is recommended to replace the head bolts when you do a head gasket. The difference in compression would be approx 35psi +/-...
Old 10-04-2010, 10:08:57 AM
Mark Birdeau's Avatar
Mark Birdeau Mark Birdeau is offline
Default Re: 1864 Cub Cadet concern
Bd, I don't know about your engine but on the older K series Kohler's the reed valve is under the valve cover.
Mark:
Old 10-17-2010, 06:49:32 PM
Compression test results, both banks are the same, so I say this kohler has had a hard live, because are other cub of same type has had great care & still doesnt use or leak a drop of oil between maintance times, with more hrs then the one with this concern.That proves that low ash oil from I H works!!!!!!
Old 11-09-2010, 07:28:55 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
The reed valve is under the cover where your breather hose enters the block. top center
Cub Cadet 122 Connor Hofford Garden Tractors and Mowers 1 02-02-2010 04:00:06 PM
CUB CADET model 1864 problem Flying mower guy Garden Tractors and Mowers 5 09-25-2009 04:49:51 PM
Need Cub Cadet help Steve B Garden Tractors and Mowers 6 04-05-2009 10:37:01 AM
Webster Mag Output Concern Tom Herd Hit & Miss Gas Engine Discussion 2 08-12-2005 08:13:34 AM
Cub Cadet hds 2145 RWBolton Small Air Cooled Gasoline Engines 2 07-30-2005 01:04:59 PM
