IHC LA fuel line check valve
this thread has 3 replies and has been viewed 1598 times
Old 11-03-2010, 08:40:16 PM
wydiver's Avatar
wydiver wydiver is offline
Default IHC LA fuel line check valve
I've heard of there being a check valve in the fuel line of a IHC LA, is it in the tank or the copper line?
Just finished restoring and will run for a while then shut down.
Thanks for all the help
Bryon
Old 11-03-2010, 08:59:57 PM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
Default Re: IHC LA fuel line check valve
It should be on the end of the gas line in the tank.
The Following User Says Thank You to Dick Graybill For This Post:
Old 11-03-2010, 09:13:54 PM
TheToolman's Avatar
TheToolman TheToolman is offline
They have new ones made up at hit & miss enterprises .They are sponcers here they cosy very little & save a bunch of cussing!!!
The Following User Says Thank You to TheToolman For This Post:
Old 11-04-2010, 09:07:20 AM
wydiver's Avatar
Took it apart and there was no ball in it. checked the drawers and found nothing that would fit. then this morning while doing the dishes I had a vision, what if a BB from a BB gun would work, ran the the shop and dropped one in and its perfect, resoldered and wahlay, perfect check valve.
Thanks again for all the help.
Bryon
Fuel Check Valve Replacement cham Hit & Miss Gas Engine Discussion 3 04-14-2009 08:28:13 PM
fuel line check ball source. Greg Shipley Hit & Miss Gas Engine Discussion 6 07-25-2007 11:10:15 AM
Fuel, check valve problems Dustin D Ehli Hit & Miss Gas Engine Discussion 20 03-27-2007 11:03:51 AM
FMZ 2 hp fuel check valve Dale Antique Engine Archives 0 11-25-2001 12:01:52 PM
check valve on fuel line Tim Griffin Antique Engine Archives 1 05-08-2001 10:53:20 PM
