Acme thread?
this thread has 13 replies and has been viewed 14634 times
Old 01-27-2011, 11:00:17 PM
Default Acme thread?
I need to have an adapter made to screw on the male thread on a telescopic pole. It's the same thread that's found in the end of paint rollers or mop handles. Does anyone know if there is a tap available to cut this thread? Size designation? By my measurements it looks like diameter of the male thread is approx. .704 to .72" with 5 threads to the inch but I haven't found anything to match this in several tool catalogs that I've checked.
Thanks for any info in this regard.
Bill
Old 01-27-2011, 11:15:01 PM
jht1057 jht1057 is offline
Default Re: Acme thread?
MSC has a large variety of ACME thread taps and dies.
Jim
---------- Post added at 10:15 PM ---------- Previous post was at 10:12 PM ----------
mscdirect.com
Old 01-27-2011, 11:59:29 PM
Rick McKay Rick McKay is offline
Here's some info for you:
http://www.sizes.com/home/handles_broom.htm
And here's the tap you need:
http://www.mcmaster.com/#acme-taps/=as3tgk
Ouch on the price
Maybe you could make this work instead:
http://www.mcmaster.com/#general-pur...e-nuts/=as3u2b
93023A664
General Purpose ACME Right-Hand Coupling Nut Plain Steel, 3/4"-5 ACME Size
In stock at $19.47 Each
Hope this helps,
Rick
Old 01-28-2011, 01:16:36 AM
Rick,
Thanks for posting. That was the information I was looking for. None of the Canadian tool catalogs that I checked had a 3/4" X 5 Acme tap listed. I see by the price of them they probably thought they wouldn't sell any!
Now I'll have to decide whether to spring for a tap or go with having a coupling nut turned down to fit a bulb changer.
Bill
Old 01-28-2011, 12:14:34 PM
Maybe cut off a paint roller handle and secure your bulb changer to the steel rod portion of the roller handle that you choose not to cut off..
You can weld or braze to it but the easiest is to thread the steel rod with whatever common thread fits and go from there.
I mount numerous items this way. Makes a great extendable handle for a horshoe magnet, for example.
Perhaps a bulb changer too.
Old 01-28-2011, 03:05:28 PM
Kid,
Thanks for the aditional suggestions. I'm leaning towards the coupling nut and a slotted broom handle adapter that I have with the male thread. The handle of the bulb changer should fit nicely inside the adapter and can clamp it with an attached screw. Just waiting for availability and price from a possible Canadian source for the coupling nut.
I note there are 5' extendable poles made for the bulb changer but would need 4 of them to reach lights in a skating arena. At about $50 for each 5' pole, decided to go with a telescopic pole with the Acme thread for about $40.
Bill
Old 01-28-2011, 05:41:47 PM
Elden DuRand's Avatar
Bill:
Duct tape?
Take care - Elden
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 01-28-2011, 07:40:54 PM
Elden,
Duct tape was going to be my backup plan! Regular or Gorilla?
Bill
Old 01-29-2011, 10:00:43 PM
Bill:
Depends on how hard you're gonna use the pole and how good a helmet you wear.
It's your executive decision.
Take care - Elden
[SIGPIC][/SIGPIC]
Take care - Elden
Old 01-29-2011, 10:09:19 PM
Elden,
Wasn't planning on using the pole & bulb changer myself so guess doesn't really matter!
Bill
Old 07-14-2017, 09:12:49 PM
I am looking for an economical way to attach a standard acme 3/4" x 5 handle to a steel plate. I have some magnetic pick up tools that have an adapter from female acme thread to a stud that is welded to the metal disc that holds the magnet. The closest thing I have found after several hours of searching the net is a 3/4" x 5 nut from McMaster Carr. I do not think the threads are deep enough to hold a handle securely.
The adapter used on the pick up tool should be an inexpensive piece, if I just knew where to purchase it.
Any suggestions? Thanks
Old 07-15-2017, 08:51:20 AM
Get a coupling nut. They're about 2" long.
https://www.mcmaster.com/#acme-coupling-nuts/=18iaekd
Old 07-15-2017, 11:45:42 AM
If this is a one time thing, you could simply saw and file the threads into a new handle.
I have seen Roy Underhill do it. He cuts a triangle shape out of paper, wraps it around the stock and marks each wrap. Then files the threads.
http://www.pbs.org/woodwrightsshop/p...wooden-screws/
This isn't quite what I remember seeing, years ago, but you will get the idea.
Here, he is actually making a steel tap using that method.
Pete Stanaitis
Old 07-15-2017, 06:57:35 PM
That would likely work fine, but at close to $30, not cost effective.
Year of my Acme? 65vette396 Oil Field Engines & Related Equipment 12 09-08-2009 03:13:09 PM
ACME threaded rod Steve Holbrook Machine Shop and Tool Talk 5 03-21-2009 01:37:08 AM
Looking to borrow ACME tap Andrew Albrecht Machine Shop and Tool Talk 6 11-08-2007 02:00:31 AM
Difference between Thread Restorer....Rethreader...and Thread Chaser??? packrat56 Hit & Miss Gas Engine Discussion 12 07-31-2007 12:59:11 PM
Acme Thread Ray Gardner Antique Engine Archives 2 03-28-2002 01:46:56 PM
