1947 John Deere D Magneto Timing
this thread has 4 replies and has been viewed 5152 times
Old 03-19-2011, 07:05:37 PM
Starvin Marvin Starvin Marvin is offline
Default 1947 John Deere D Magneto Timing
I am trying to time a 1947 John Deere D with Edison magneto. Impulse fires on 6:30 and 11:30 positions on flywheel instead of 3:00. Engine is timed correctly. Can anyone advise how to adjust the magneto?
Old 03-19-2011, 08:45:20 PM
Dempster Dempster is offline
Default Re: 1947 John Deere D Magneto Timing
When you were getting the engine timed to put the mag on having LH cylinder, #1 on flywheel up on TDC compression were the drive slots in the governor horizontal ? If not the governor has to be lifted and set right so those are horizontal. The impulse on the Edison CD 2 is not adjustable and should be fixed at 35 degrees. However if someone has been in it and didn't time the dist rotor correct it will be off. There is a slot or hole should be able to see a L come up and line up with punch or line mark on the other gear inside the mag. It's a CCW or LH left hand drive mag facing the drive so use the L mark not the R mark for RH. The Edison Splitdorf CD 2 mags have to be timed to the engine correctly because they fire on compression stroke only so can't reverse the wires if get it 180 deg off like with a Wico or FM J or X mag that fires on compression and exhaust.
The Following User Says Thank You to Dempster For This Post:
Old 03-19-2011, 09:18:03 PM
Jeremy Hartle Jeremy Hartle is online now
You can take the impulse lug off the governor without taking the governor loose from the engine.Just turn it where you need it and put it back on. If i was home i would scan the procedure out of the book. If you can wait till next weekend ill do it. Good Luck, Jeremy
The Following User Says Thank You to Jeremy Hartle For This Post:
Old 03-19-2011, 10:36:15 PM
1937 to 1953 D has different governor and uses flange mount magnetos. The lug driving the mag is keyed to the governor shaft not adjustable like on the earlier 1924 to 36 D or whenever they changed.
Old 03-20-2011, 11:40:06 AM
Mitch Malcolm Mitch Malcolm is offline
Check and make sure your flywheel is in time with the crankshaft !!
The Following User Says Thank You to Mitch Malcolm For This Post:
John Deere BO Timing?? RIRR Antique Farm Tractors 2 05-20-2007 10:34:41 AM
John Deere DLTX 63 for a D 1947 Ron Davis Antique Farm Tractors 3 11-26-2006 12:30:26 AM
timing John Deere Mag Dale White Hit & Miss Gas Engine Discussion 1 06-26-2006 08:40:59 AM
john deere mag timing John Hopkins Magnetos, Ignition Coils and Spark Plugs 8 03-23-2006 09:39:50 AM
John Deere 3HP Mag. Timing Bob Kelly Antique Engine Archives 3 07-11-2002 12:10:56 AM
