Farmall Super A? Question
this thread has 12 replies and has been viewed 4747 times
Old 04-27-2011, 10:33:40 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Farmall Super A? Question
hello, i have a farmall A with hydraulic lift and the serial # starts out with FAA and bore for #1 piston is 3" ,#2 & #3 piston is 3&1/4", #4 piston is 3".. What the heck? Is this how the piston size is for Super A's? Do i even have a super A? The sticker on the hood reads ONLY "A-Cultivision" Can anyone tell me anything about this A? or Super A? what is it and is this how the bore should be? Im thinking i might have an engine that has been screwed with and would this engine even run ok with the bore size as measured? Thanks stakers!
Old 04-27-2011, 11:05:38 PM
Sonny Reese Sonny Reese is offline
Default Re: Farmall Super A? Question...
It should still run, but not sure about the vibration issue here!
It would sure sound weird while running!---someone was too tight to rebore all 4 to match,--or that would be my opinion here!---I never heard of only re-boring half of an engine then putting it back together! thanks; sonny
The Following User Says Thank You to Sonny Reese For This Post:
Old 04-27-2011, 11:24:27 PM
I can't imagine there not being a vibration problem having both larger pistons on the same side of the crankshaft.......
I think you should either finish the job or sleeve them back to standard.
Old 04-28-2011, 05:38:43 AM
S Mullins S Mullins is offline
i know a guy that used to have the front cyl on a pulling truck engine a smaller bore,so if he got protested he would use that cyl to volume test! yes it was balanced the same as the other pistons and he was way over total cu in limit.
Old 04-28-2011, 11:58:18 AM
Casemaker Casemaker is offline
maybe you have a tractor built for tractor pulling.....
Old 04-28-2011, 10:07:45 PM
Thank you all for the info so far..Im still trying to find out if this is a Super A or A cultivision or possibly a Super A1? Seriel number reads FAA- 34281 and the engine number reads 344677G And i will let everyone know how it runs when i get the gasket set in...I guess its impossible to find a head gasket to this certain piston size that this engine has....I got this tractor the other day where it sat in the weeds unused for many yrs...here is the pic..tractor also has a fast hitch on the rear. thank again stakers for the given knowledge.
Old 04-28-2011, 11:13:43 PM
Junkologist's Avatar
The hydraulic lift was only available on the Super A, as far as I know.
Are you sure you have a 3 1/4" bore and not 3 1/8" bore? The standard bore for an A and a Super A would be 3", but most rebuild kits are supplied with the larger 3 1/8" bore sleeves that were standard on the later 100 series tractors. I doubt that someone would go through the trouble of actually boring the engine out to 3 1/4" especially since it is a wet sleeve engine.
Mike
SmokStak member #146
The Following 2 Users Say Thank You to Junkologist For This Post:
Old 04-29-2011, 06:35:00 AM
Yes,its a 3&1/4" bore. My younger brother who has had a few farmall super engines couldnt believe it also..Im waiting on a gasket set to see how the engine runs! This was for sure built, the 3" pistons are cast and the 3&1/4" pistons are aluminum..
Old 04-29-2011, 12:05:46 PM
Weezer Weezer is offline
Hey, sometimes you just gotta use what you have.
I say run it. It's one of a kind........Hopefully!
Jim
The Following User Says Thank You to Weezer For This Post:
Old 04-29-2011, 02:59:53 PM
Candy T. Candy T. is offline
That's right Weezer!
You should see some of the combinations we have come up with.
No harm in using what you have on hand. It does not matter what it looks like; so long as it does the job. Ours are Workhorses not Showhorses!
You won't find our stuff at the shows.
Old 04-29-2011, 08:36:56 PM
Phil Johnson's Avatar
Candy, the "Workhorses" at the shows around here seem to attract more attention than the "Showhorses". They are the ones usually belted up to something or pulling an implement out in the field.
Old 05-02-2011, 11:32:29 PM
That's right Phil! The owners aren't afraid to get them dirty and scuffed up. I love watching them in action as they intended to be use.
Old 05-04-2011, 09:25:22 PM
Casemaker, i think the engine was built for pulling...I never had a super engine run this strong and with such a fast running gear! It really felt i was getting 20 mph up the driveway...Ithink these tractors were set for 11-12 mph in high gear?...No odd jumping or engine throw when running...I was very surprised for this running with the 3&1/4" pistons...I do get a puff of smoke from the stuck rings when i goose it...Hopefully i can get that to go away with a can of engine restore..I will close this thread by saying thank you to all stakers for the info given...I defenitetly got a 1 of a kind super A! hope i can pull in a lower pulling class this summer..I guess i will have to weight it down alot.
Farmall Super A-1 Lloyd J. Antique Farm Tractors 1 04-04-2011 05:14:35 PM
Farmall H or Super H? Which do I have? Karl T Schwab Antique Farm Tractors 5 02-03-2011 06:33:20 PM
Farmall Super A or A1?? Mart Antique Farm Tractors 5 08-27-2008 08:54:06 AM
Farmall super C Ihorse Antique Farm Tractors 0 10-08-2007 08:30:42 PM
Farmall Super M and H tractor boy Antique Farm Tractors 7 07-09-2007 09:33:18 PM
