"bobcat" by Whitman & Robinson info wanted
this thread has 13 replies and has been viewed 5111 times
Old 07-09-2011, 12:01:09 PM
grega's Avatar
grega grega is offline
Default "bobcat" by Whitman & Robinson info wanted
Im looking for any informaitio on my Bobcat made by Whitman & Robinson in weedsport ny. It was made sometime in the 1950s. It has a snowplow, and is four wheel trive and steers like a bull dozer. The engine is an opposed 2 kohler with a bore of 3 5/8 and a stroke of 3 1/4 inches. It is a model W serial #228. the rear ends are early fords placed back to back, with a sprocket in between. the sprocket is driven by a chain that is driven by the transmition wich is bolted directly to the clutch and engine. Later units were made by caiuga mfg(i hope i spelled that right). any info apreciated. Pics soon.
-Greg
"There only origionial once"
Old 07-09-2011, 12:54:06 PM
grega's Avatar
Default Re: "bobcat" by Whitman & Robinson info wanted
Here are the pics.
-Greg
Name:	Whitman and robenson bobcat 001.jpg
ID:	110241   Click image for larger version
Name:	Whitman and robenson bobcat 002.jpg
ID:	110242   Click image for larger version
Name:	Whitman and robenson bobcat 003.jpg
ID:	110243   Click image for larger version
Name:	Whitman and robenson bobcat 004.jpg
The Following User Says Thank You to grega For This Post:
Old 07-09-2011, 01:43:26 PM
K D Redd K D Redd is offline
Have you tried the current Bobcat company? This MAY be where they started.
Kent
Old 07-09-2011, 01:50:53 PM
grega's Avatar
There is no relation to todays bobcat.
-Greg
Old 07-11-2011, 11:30:53 AM
grega's Avatar
Has anyone ever seen one? Any information? Anyone know what model the Kohler is(bore is 3 5/8 stroke 3 1/4)?
Iv been working on it little by little over the past couple of days. It needs alot of brake work. It had two stuck valves, but after i freed them up i put some gas in the carb and it fired a couple of times. Besides brake work all it seems to need is fuel pump work.
-Greg
P.S. the second company to manufacture this machine was cayuga mfg
Old 01-04-2013, 09:47:57 PM
nannasdad nannasdad is offline
Question Re: "bobcat" by Whitman & Robinson info wanted
hi I saw your post about the bobcat by whitman and robinson .I am in the process of buying one and have been searching for info and articles about them and was wondering if you were able to find any. thanks mark
Old 02-25-2015, 10:43:07 AM
jtbartlett jtbartlett is offline
Just to bump this thread again....I also have a Whitman & Robinson sidewalk plow powered by a kohlerk662 opposed twin. I had to do some carb work, the carb is a zenith 228, parts somewhat available, rebuild kits available. I haven't torn into the machine too much but I am looking for any info -at all- on these machines. Looks like it will go go go with the narrow gauge 4wd. Does anyone know what transmission is in these? I have seen rockford clutches on other industrial kohler powered machines. Anyone know for sure? I'd like to correspond with anyone who has worked on these or has some info. I would like to run a hydraulic pump off of the engine but, as I said, I haven't gotten a chance to get into it yet.
Old 02-25-2015, 05:42:07 PM
grega's Avatar
JT can I see some pics of yours?
-Greg
Old 02-25-2015, 10:06:27 PM
Absolutely. When I can find it again under the snow. Mine has a full cab. The original v blade is missing but I got it with a ford blade instead. Have you ever seen any documentation on these machines? The internet has been suprisingly barren. I will take some pics and post them here. There must be more in New England. I don't know what kind of distribution Whitman & Robinson had in the early 60's.
Old 02-26-2015, 12:08:08 PM
OrgWayne OrgWayne is offline
There is first year, I,m guessing case in a town , that looks a lot like yours can just fit your hand between the tires 15/16 inch I Think
wayne
Old 02-26-2015, 12:32:54 PM
[ATTACH][ATTACH][ATTACH]Click image for larger version
Here are a few pictures. I don't have any information on it at all.
ID:	219536   Click image for larger version
ID:	219537   Click image for larger version
Old 02-26-2015, 01:24:08 PM
grega's Avatar
Does yours have the single rear end with chains to the wheels or the dual rears with the wheels on the axel?
-Greg
Old 02-26-2015, 10:01:20 PM
Both front abd rear wheels are chain drive. There is a central sprocket which drives the wheels fore and aft. Is the rear end dfinitely Ford? Do you know what ford models the drivetrain came from? I'm interested in identifying the clutch and transmission in case there are issues there. I drove it a little. The hydraulic clutch resevoir and cylinder will need some work. Its in a bad spot in the middle of the cab floor. I got the thing for free which is fantastic.The Kohler was blowing oil as the case was filling with gas. Hopefully a needle valve in the carb will stop that. Have you seen any others? No idea what the proeuction numbers were.
---------- Post added at 09:01 PM ---------- Previous post was at 08:39 PM ----------
Old 02-27-2015, 07:14:58 AM
grega's Avatar
Then yours is the later model.
-Greg
"Avance" engine pictures wanted Inter Bloke Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-28-2010 07:05:13 AM
Info wanted:"Missing Link" vintage welder W. Mocek Welding Shop 0 07-23-2009 07:14:08 PM
Wanted: Kohler "controller board" part #B292302A. asuperglide Kohler Generators 1 07-02-2009 01:10:07 AM
Info Wanted "The Trusty" Engine Chuck Moss Antique Engine Archives 1 08-12-2004 08:20:11 PM
