1922 Fairbanks morse dishpan ignition question
this thread has 8 replies and has been viewed 3296 times
Old 08-26-2011, 10:21:28 AM
DrewellLX9 DrewellLX9 is offline
Default 1922 Fairbanks morse dishpan ignition question
I recently purchased a dishpan 1 1/2 hp z type engine equiPped withe a buzz coil, I need any information on how to wire everwthing up to make the engine run! Like battery voltage, where the three terminals on the coil go and how the battery hooks up to the arrangement!!! And info would be greatly appreciayed! The motor has been competely restored, all I need to know is how to wire everything up!
Old 08-26-2011, 12:01:28 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Default Re: 1922 Fairbanks morse dishpan ignition question
Here you go: http://www.old-engine.com/magbuz.htm
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
Old 08-26-2011, 12:45:13 PM
BobRR BobRR is offline
Does it have the orginol battery/coil box on the side of hopper? Any small 6 or 12v battery will work. Bob
Old 08-28-2011, 12:56:45 PM
Thanks for the info, I finally go the ignition to work! Now I'm hing problems getting it to start! Is there a certain way to time the engine ect, also which way does the flywheels need to turn in order to run???? Do I pull the flywheel backwards or push foreward to run??? Sorry for the stupid question, I'm new to this and need all the help I can get!!!!! To answer your question bob, yes it has the original battery box with original coil, currently I'm running it on a basic 6v battery!!!! Again any info will be appreciated
Old 08-28-2011, 01:04:38 PM
stufforbud stufforbud is offline
You need to pull the flywheels backwards, (pull the top away from the hopper), and try to get the spark right at top dead center for starters so it won't kick back if you pull it thru quickly.
Good Luck, Bud
Old 08-28-2011, 01:44:05 PM
Is the buzz coil suppsed to run all the time or is there something om the engine that only makes it spark at certain times, right now the coil buzzes all the time until I trip the cutoff swith on the back of the battery box
Old 08-29-2011, 03:49:50 PM
No it shouldn't buzz all the time. Have you got the wire from the switch going to the timer that is on the push rod by the governor? Bob
Old 08-29-2011, 05:16:40 PM
Yes I do, I might have something going on at the switch by the governor, how does that switch right there at the governor actually tell the buzz coil to activate??? Thanks for the help bob!
Old 09-08-2011, 10:41:30 AM
Bigjoedo's Avatar
Bigjoedo Bigjoedo is offline
DrewellLX9,
This is how it was explained to me by David Lyons.
"The 'push rod lifter' as you have named it, travels backwards with a dimple on the camshaft and grounds the buzz coil when it touches the metal plate on the timer...There has to be a good path for the current to flow. So, if any paint or rust is interfering get rid of it. an easy test is to hook up your buzz coil, roll the engine over, and see if it will buzz.
The metal plate should be insulated from the engine block so that it doesn't ground out the coil until the push rod reaches it" You adjust the timing by adding or subtracting spacers. Available at www.hitnmiss.com
It was confusing to me as well.
Bigjoedo
Fairbanks morse Dishpan Jordan Antique Engine Photos 6 03-07-2015 01:12:39 PM
Fairbanks-Morse Z Dishpan Question Zira Hit & Miss Gas Engine Discussion 2 09-22-2010 09:57:20 AM
Fairbanks Morse Dishpan Ray Cardoza Hit & Miss Gas Engine Discussion 15 01-15-2010 02:05:35 PM
Fairbanks Morse Dishpan Jordan Hit & Miss Gas Engine Discussion 2 03-26-2007 07:23:47 PM
Fairbanks Morse Dishpan with Battery Ignition Kevin Woodruff Hit & Miss Gas Engine Discussion 16 12-30-2005 10:02:55 PM
