1920 Hercules Ignitor?
this thread has 3 replies and has been viewed 2002 times
Old 09-13-2011, 02:28:11 AM
1916Z3 1916Z3 is offline
Default 1920 Hercules Ignitor?
I have a 1920 Hercules 1 1/2 E that I am slowly getting back together to hopefully run once again. But as usual I have none of the ignition parts. I plan to just make up something on my own that will adapt to existing mounting points and what not as to not permanently alter it.. anyways.. didn't this engine originally come with an ignitor? cause it now has a plate bolted onto it with sparkplug in it.. if it is supposed to have ignitor.. where can I find one? I have looked around ebay and did google searches trying to find one with no such luck.. making an engine run with ignitor way easier then messing around with points..
Old 09-13-2011, 09:09:02 AM
oldproff oldproff is offline
Default Re: 1920 Hercules Ignitor?
There is a person who offers new, I think he said hand made ignitors, for sale regularly. Bill K
Old 09-15-2011, 04:12:18 PM
Exclamation Re: 1920 Hercules Ignitor?
I think the original igniter was a 303 K-26, and the engine used a Webster TriPolar type AM (one magnet). You should be able to get the assembly from H&M Enterprises, but it won't be cheap!
Old 09-18-2011, 10:49:22 PM
Yeah, I am going to be making an ignition for it using High tension coil. cannot justify spending more on a mag/ignitor then I did for the engine and all of the other parts I have gotten for it so far.
1920 3hp IHC William Tomashek Hit & Miss Gas Engine Discussion 2 01-10-2011 10:53:00 PM
Hercules/Economy Ignitor Wrenches Loren E Hit & Miss Gas Engine Discussion 10 01-22-2010 06:56:16 PM
Hercules Ignitor Shaft Repair. JKKD Hit & Miss Gas Engine Discussion 2 02-28-2009 11:56:01 PM
Hercules or Economy magneto bracket and ignitor Polfin Hit & Miss Gas Engine Discussion 3 02-14-2009 11:17:53 PM
Removing Ignitor springs on F/B headless Ignitor Bob Johnson Hit & Miss Gas Engine Discussion 1 07-21-2008 06:42:45 PM
