10 hp Fairbanks/AB33 mag timing
this thread has 2 replies and has been viewed 1634 times
Old 11-09-2011, 07:30:05 PM
Joes Shop Joes Shop is offline
Default 10 hp Fairbanks/AB33 mag timing
I just had a mag rebuilt and a new trip arm installed for my 10 FM Z engine. Couldn't get it to fire up....would get a couple shots and then nothing. Good spark and even better compression. I had an engine friend help me belt it up and found that the timing was very much retarded. It labored to run. No wonder it wouldn't start. Timing marks on gear and crank are correct. How many degree's after top dead center for starting? I'll need to shim up the mag a little at a time to get it right. Or are there any better ideas?????
Old 11-10-2011, 10:27:23 AM
Exclamation Re: 10 hp Fairbanks/AB33 mag timing
On retard, the engine should fire at or neat TDC, not after. Advanced, should fire around 20 degrees BTC.
Old 11-10-2011, 05:15:46 PM
Default Re: 10 hp Fairbanks/AB33 mag timing
Thanks Andrew,
I will get it timed that way. Should make it start alot better. I've got a FM book on the way and that will help too.
Joe
Fairbanks Morse 3hp AB33 Magneto newway1978 Hit & Miss Gas Engine Discussion 0 10-16-2010 11:16:33 PM
Need help installing an AB33 mag on a Fairbanks Canadian made Hit & Miss Gas Engine Discussion 6 07-12-2009 08:14:05 AM
1 1/2 hp fairbanks z timing Norman McGinnis Hit & Miss Gas Engine Discussion 5 10-29-2006 09:01:17 PM
AB33 & Fairbanks F1 Magneto Collector Rings Andrew Albrecht Magnetos, Ignition Coils and Spark Plugs 0 09-09-2006 06:40:28 PM
15 hp Fairbanks Morse AB33 lonnie Antique Engine Archives 0 06-05-2004 09:19:45 PM
