Briggs Overhaul Questions
this thread has 3 replies and has been viewed 1588 times
Old 07-18-2004, 12:52:36 PM
Jim H.
Default Briggs Overhaul Questions
Had to replace the rings in a 14.5 HP OHV engine. This is a first for me. Reading the books (repair manuals) it talks of the importance of getting the right thickness gasket on the cases. How important is this? The old gasket only has one small spot that is torn, so was thinking of the handy-dandy RTV gasket maker. Is that OK?
Old 07-18-2004, 01:51:05 PM
Bob (ND)
Default Re: Briggs Overhaul Questions
So long as you have some endplay on the crankshaft, you'll be OK... probably between .005" and .020".
Old 07-18-2004, 04:17:29 PM
Jim Freshman
Why risk an oil leak for $3 doesn't make sense to me. Are you using the other gaskets over too? If so not a good idea.
Old 07-18-2004, 11:21:45 PM
ldj1002
Default 2 chargers
Not necessarily a bad idea. For years I've reused gaskets, not to save money but for convenience. Because of poor planning or impatience on my part I'll tear something down and rather than wait or travel 60 miles to get new gaskets, I'll use the old ones or make new ones. Never had a problem. Of course common since has to be used. If it is damaged, make one. If you make one, use same thickness material. If you haven't got the right material, wait till you can get a new one or get the right material. I can make most gaskets faster than I can go to the phone and order one and for sure faster than driving 60 miles for one.
Briggs 92988 time to overhaul sopicki Garden Tractors and Mowers 6 07-12-2019 08:34:55 AM
Briggs 5S Questions JamieHook100 Small Air Cooled Gasoline Engines 18 04-26-2019 01:25:44 AM
Briggs 3hp Questions? Railroads Small Air Cooled Gasoline Engines 3 03-20-2014 01:06:30 AM
Briggs U questions Bruce A Small Air Cooled Gasoline Engines 7 03-05-2012 12:15:05 PM
Onan 6.5nh 3CR/16004P Overhaul questions ChrisCarbaugh Onan Generators 4 09-14-2011 08:57:48 AM
