Recommended source for propane conversion
this thread has 3 replies and has been viewed 4640 times
Old 12-07-2007, 04:40:33 PM
tcvt tcvt is offline
Default Recommended source for propane conversion
I hope this is the best section of the forum to ask about a recommended propane conversion. I have an old Honda G80 on a E3500 generator. I have come across several on the web. Thanks.
http://www.propane-generators.com/
http://www.propanecarbs.com/small_engines.html
http://www.hendrixsystems.com/index.htm
Old 05-26-2008, 11:32:58 PM
rrfxxxr rrfxxxr is offline
Default Re: Recommended source for propane conversion
I like the first one of the three.
Old 05-27-2008, 07:20:00 AM
John A John A is offline
www.uscarb.com or www.rutherfordequipment.com
Used the conversion from us carb on my 13hp honda,
runs good.
Easy to install, good support staff.
John
Old 05-27-2008, 01:53:51 PM
Forrest A's Avatar
To properly convert a gasoline engine to LP you need to install a higher compression piston(s) otherwise you will see upt 20% loss in HP.
Forrest A
10.0CCKAJ propane conversion - new carb or conversion kit? DrCharles Onan Generators 4 12-26-2011 12:14:28 AM
Propane Conversion pnora Onan Generators 8 01-29-2011 05:44:01 PM
Propane conversion? mdlbldrmatt135 Military MEP and Aircraft Gen-Sets 17 07-23-2010 05:27:36 PM
CCK gas to propane conversion Ray Griffiths Onan Generators 6 08-16-2009 09:28:49 AM
Propane conversion ihorse Antique Engine Archives 4 06-06-2004 08:11:01 AM
