Champion RE-7 Compressor Pump Rebuild
this thread has 0 replies and has been viewed 4562 times
Old 05-20-2008, 09:36:28 AM
toophar toophar is offline
Default Champion RE-7 Compressor Pump Rebuild
Hi guys..
I have a 1944 Champion RE-7 two stage air compressor that was running, but in bad condition. I have started dismantling it.
I have removed the manifolds and valves, but a lot of grime has got in through the low pressure intake valve and has coated the LP piston. Also some water welled in the LP piston chamber too.
It's been like this a few days and I'm concerned about rust etc.. do I need to get the pistons out as soon as possible? The piston heads are domed and the cylinder head is a single casting.. the pistons have to come out through the bottom. Should I do this by lifting the head off first, or should I try to detach the piston rods from the crank first?
Are the piston rings going to have a problem clearing the bottom of the cylinder bore? Is the gunge that has presumably worked its way down the side of hte piston wall likely to mean the rings will have to be replaced?
Any advise most welcome.. thanks. Will try nad get some photos up soon.
DJB fuel transfer pump rebuild? jas67 Onan Generators 19 04-17-2008 02:27:49 AM
L654 fuel pump rebuild kit adventure and FYI eeleater Kohler Generators 4 12-09-2007 09:18:30 PM
Need Shaft seal on RE-7 Champion Air compressor and some. Ram Machine Shop and Tool Talk 5 06-22-2006 08:26:20 PM
Champion Compressor Randy Wells Hit & Miss Gas Engine Discussion 4 03-25-2005 10:24:08 AM
fuel pump rebuild JIM KIRKWOOD Antique Engine Archives 0 11-14-2000 12:16:59 PM
