Parts Washer Fluid?
this thread has 6 replies and has been viewed 8831 times
Old 05-26-2008, 11:55:34 AM
NAMPeters
Question Parts Washer Fluid?
Need to upgrade my cleaning process and am wondering what people are using for fluid/solvent in their parts washer?
Old 05-26-2008, 12:23:41 PM
Sky
Default Re: Parts Washer Fluid?
Mineral spirits works good.
Old 05-26-2008, 12:49:56 PM
Oilzum's Avatar
Oilzum Oilzum is offline
Super Agitene from Grainger, I use it in a recirculating tank. Have had really good results. Extremely long tank life, several years with light use (scrape as much crud off as you can and use it for final clean only). I have used the biofriendly stuff but you need a heated tank for it to work good and it looses its potentcy in about 90 days if you use it alot, smells bad if you allow it to go unchanged
Old 05-26-2008, 12:52:15 PM
drsfmd drsfmd is offline
I like "purple power"... it's around $5 a gallon at walmart, and I cut it with 3 gallons of water.
Old 05-26-2008, 01:10:22 PM
mineral spirits.about a buck on sale.lasts for years.been using mine for 20 years with the occasional replenishment.its a 30 gal washer and have added about 10 gals. over the years.
Old 05-26-2008, 02:25:10 PM
Ackman's Avatar
Ackman Ackman is offline
BRAKE Parts Cleaner or Carb Cleaner works for me!
Old 05-26-2008, 05:33:15 PM
K D Redd K D Redd is offline
I use Kerosene with a pump pumping the fuild through a regular car oil filter of the Chrysler/Ford/Allis-Chalmers/ Toyota type. I have to change the oil filter every once in a while and all some kerosene every once in a while.
Kent
Hopper cooling fluid Walt Roys Hit & Miss Gas Engine Discussion 20 02-11-2008 06:20:11 PM
Neat Maching Fluid: Anchorlube PaulGray Antique Engine Archives 5 05-13-2004 02:01:24 AM
Maytag Wringer washer parts?? Denny Foster Maytag Engines and Collectibles 4 12-08-2002 11:46:31 AM
Washer fluid in the hopper Ken Fall Antique Engine Archives 11 03-09-2002 12:20:45 AM
Parts Washer Jim Moody Antique Engine Archives 3 07-22-2000 12:00:01 PM
