Spark plug size for maytag 72
this thread has 1 replies and has been viewed 3690 times
Old 09-02-2008, 09:04:22 PM
Rob Williams Rob Williams is offline
Default Spark plug size for maytag 72
can any one tell me what size plug is needed on a maytag model 72 twin?And what is the best way to try to start motor for the first time. Thanks
Old 09-02-2008, 10:36:47 PM
Exclamation Re: Spark plug size for maytag 72
Champion J 8-J will work, the J 17 & 19 LM looks more to scale, Maytag 14mm script plugs turn up on Evilbay, take your pick!
Replacement Spark Plug for Maytag Uprights?? Modern Plug? enginesilo Maytag Engines and Collectibles 3 08-31-2008 01:21:57 AM
Spark Plug to use in a Maytag 92? enginesilo Maytag Engines and Collectibles 11 05-27-2008 11:01:46 AM
Maytag 72 spark plug The one banger boy Hit & Miss Gas Engine Discussion 15 09-03-2007 09:10:44 PM
B & S spark plug wire size kelby Small Air Cooled Gasoline Engines 5 03-20-2006 04:53:51 PM
Briggs Spark Plug Tap Size Smoke Small Air Cooled Gasoline Engines 2 04-23-2005 07:42:36 PM
