Help with Curtis Two Stage Air Compressor
this thread has 2 replies and has been viewed 2296 times
Old 09-16-2008, 11:26:21 PM
Jim Hester Jim Hester is offline
Default Help with Curtis Two Stage Air Compressor
I have a Curtis air compressor that went down on me today. I cannot find any data plate that tells me a model or size. I need to measure the stroke and bore yet. Any advice would be aw some. Also all the part numbers that I find on this start with TF if that helps. Thanks
Old 09-25-2008, 01:49:44 PM
GimpyRobb GimpyRobb is offline
Default Re: Help with Curtis Two Stage Air Compressor
What "went down"? Did the motor die, or does it still pump, just not build pressure?
Old 09-30-2008, 09:39:42 PM
four reed valves broken, cylinder walls pitted bad, would only biuld to 75 psi no higher.
curtis compressor Kevin Hit & Miss Gas Engine Discussion 16 01-22-2012 09:50:22 PM
Curtis compressor Denis Rouleau Antique Engine Archives 4 05-16-2004 11:21:39 PM
Curtis Air Compressor Wesley Phillips Antique Engine Archives 6 11-29-2002 04:06:39 PM
Curtis Air Compressor Tim Wilson Antique Engine Archives 0 12-31-2001 07:49:35 PM
Curtis Air Compressor Roy, TX Antique Engine Archives 6 12-06-2001 02:46:26 AM
