What does T.I.R. mean?
this thread has 3 replies and has been viewed 23264 times
Old 10-14-2008, 08:42:06 PM
Rex Piekarczyk's Avatar
Rex Piekarczyk Rex Piekarczyk is offline
Question What does T.I.R. mean?
In the machine shop world, what does T.I.R. mean?
Old 10-14-2008, 09:15:44 PM
kevin johnson kevin johnson is offline
Default Re: T.i.r.?
Total indicated runout.
The Following User Says Thank You to kevin johnson For This Post:
Old 10-14-2008, 10:53:03 PM
Tanner Remillard's Avatar
Default Re: T.i.r.?
Its a term used when "dialing" in a part in a lathe or mill. If you need to have 2 diameters say within .001 run out, your dial indicator should read .001 or less run out of the 2 diameters to each other. Also known as concentricity. Blueprints will generally state how concentric all diameters of the part need to be to each other.
The Following User Says Thank You to Tanner Remillard For This Post:
Old 10-15-2008, 07:40:14 PM
Beanscoot Beanscoot is offline
Default Re: T.I.R.?
Another way to look at it... if a shaft in a lathe chuck is a thousandth low on one side, and a thousandth high on the other, then the TIR is two thousandths, since that's the total.
So having a shaft chucked .001" off to one side will produce .002" TIR.
The Following User Says Thank You to Beanscoot For This Post:
