Elecrolysis & Aluminum
this thread has 1 replies and has been viewed 1961 times
Old 10-14-2008, 11:33:43 PM
Rex Piekarczyk's Avatar
Rex Piekarczyk Rex Piekarczyk is offline
Question Elecrolysis & Aluminum
I have some aluminum pistons that have become one with their steel wristpins & rods. What would happen to the aluminum if I put them in an elecrolysis tank?
Old 10-15-2008, 07:45:16 PM
Beanscoot Beanscoot is offline
Default Re: Elecrolysis & Aluminum
I would imagine it would dissolve.
A friend works at an anodizing shop and tells me if there is any bit of steel embedded in an aluminum part which goes through the process, it will cause the aluminum around it to dissolve away.
But maybe one could arrange the conditions to not do this? It would be tough because aluminum is much more reactive than steel and tends to sacrificially protect the steel.
The Following User Says Thank You to Beanscoot For This Post:
Aluminum, other than paint.... HoMade Paint Shop 6 12-13-2008 02:43:44 PM
Aluminum piston, aluminum cylinder? NAR Scale Model Engineering 9 03-11-2008 02:02:27 AM
need help casting aluminum Mac Leod Hit & Miss Gas Engine Discussion 7 11-20-2006 11:36:56 PM
Aluminum I.D. Tags Sky Hit & Miss Gas Engine Discussion 1 03-29-2005 09:30:58 AM
aluminum help mike Antique Engine Archives 10 02-07-2001 06:14:57 PM
