Source for copper or brass end caps
this thread has 5 replies and has been viewed 4188 times
Old 11-01-2008, 11:11:18 AM
Default Source for copper or brass end caps
I have a piece of 3 1/16 OD copper pipe that I want to convert to a gas tank. Where would I look for end caps to fit this pipe? I've tried Home Depot, they look at you like you're crazy.
Old 11-01-2008, 11:43:35 AM
Gene O. Carpenter's Avatar
Gene O. Carpenter Gene O. Carpenter is offline
eMail NOT Working
Default Re: Source for copper or brass end caps
Leonard,
Look in the yellow pages for the nearest plumbing supply company, if it's a standard size made in the USA they should have it and they won't look at you like you're crazy..
Gene
SOOO MANY TOYS,SOOO LITTLE TIME,SOOO LITTLE $$$ TO BUY ONLY SO MANY OF THESE OLD BOY'S TOYS!!!
The Following User Says Thank You to Gene O. Carpenter For This Post:
Old 11-01-2008, 04:34:46 PM
go to plumbing supply and get end caps for 3" od copper.you will need to turn down your pipe for them to fit
The Following User Says Thank You to Ed Radtke For This Post:
Old 11-01-2008, 05:33:11 PM
Rag
I just ordered brass tubing from"onlinemetals.com". They appear to have a big inventory of goodies. Could be worth a look.
Old 11-01-2008, 06:47:34 PM
Francis Francis is offline
Why not cut out two round flat plates from a copper sheet and then silver solder them on the ends of your pipe. I have fabricated a gas tank from an old fire extinguisher using this method. Make sure that there is vent hole in fabricated tank before silver soldering the final end piece.
Old 11-01-2008, 07:12:20 PM
K D Redd K D Redd is offline
Use Phos-Copper to weld copper with an act/oxy torch.
Kent
The Following User Says Thank You to K D Redd For This Post:
Source for copper o rings? Dan Wiese Hit & Miss Gas Engine Discussion 5 09-10-2008 05:26:03 PM
Copper crush gaskets source. Greg Shipley Oil Field Engines & Related Equipment 3 04-30-2008 06:54:03 PM
Need source for Copper jlwright Scale Model Engineering 6 09-01-2007 03:39:06 PM
Brass or Copper Oxidation Removal bimjy Paint Shop 9 01-29-2006 11:45:36 PM
Source for brass pipe Benny Mckheean Antique Engine Archives 5 12-14-2004 10:16:37 PM
