Removing thingy from crankshaft.
this thread has 2 replies and has been viewed 2193 times
Old 11-12-2008, 02:21:06 AM
geckolover1234 geckolover1234 is offline
Default Removing thingy from crankshaft.
Howdy all,
I'm currently restoring a 1975 'Briggs & Stratton' Engine, and would like to remove the small Metal Disc the Bladeholder bolts onto. This Disc is attached to the Crankshaft using a Key. I don't own a 'Puller', please give me some advice, as bashing the thing could damage the Crankshaft.
tonycrossley@yahoo.com for direct contact.
Old 11-12-2008, 09:04:56 AM
grub54891's Avatar
Default Re: Removing thingy from crankshaft.
The best bet is using a puller,If you are not going to use a puller much you could rent one or go to one of them discount stores and see what they have.Usually pretty cheap,but it'll work .You could try heating the adaptor with a propane torch,it may wreck the seal but I assume you are replacing it anyway.Tom
Old 11-12-2008, 12:29:28 PM
Exclamation Re: Removing thingy from crankshaft.
Look in a supply catalog and get yourself a puller set. I picked up a 4 puller set for $45! Place the blade bolt in place, screw in all the way, then back out about 1/4" Center of puller on the bolt, apply pressure than tap adapter with hammer to shock it loose. If it is really tight on the shaft, you may have to pull it all the way off
Rust removing Chris J Hit & Miss Gas Engine Discussion 21 08-15-2008 09:31:39 PM
Removing flywheel or BobM Hit & Miss Gas Engine Discussion 4 04-28-2008 03:22:22 PM
Removing stuck roller bearings from crankshaft. Jim Gorter Hit & Miss Gas Engine Discussion 8 03-03-2005 03:26:57 PM
removing 7 hp flywheels... Matt Page Antique Engine Archives 10 05-26-2004 06:48:04 PM
removing flywheel steve hales Antique Engine Archives 7 11-20-1999 08:07:31 PM
