Central Machinery lathe
this thread has 3 replies and has been viewed 6920 times
Old 11-12-2008, 11:00:30 PM
vern0n's Avatar
vern0n vern0n is offline
Default Central Machinery lathe
I have this small lathe I got from Habor frieght a couple of years ago. It was working fine up till the other day. Now the motor vibrates, doesn't have much power, and the speed won't change. My guess is the electronic control board. Anybody else have this problem? How do I fix it?
Old 11-13-2008, 12:50:12 AM
John Newman, Jr.'s Avatar
Default Re: Central Machinery lathe
Does it have a servo driven variable speed pulley arrangement? Your symptoms sound like it may have a sheared key, something is slipping or something has come apart in the drive.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 11-13-2008, 10:20:34 PM
vern0n's Avatar
The gears all look good. I even disengaged everything. It is direct drive with an electronic control board. I wondered if maybe a gear or something was bad, but I would think even if that was the case I should still be able to veri the speed by the knob, (a rheostat).
Old 11-13-2008, 11:12:42 PM
Brad Kelley Brad Kelley is offline
2 complaints I've heard about the chinese lathes have been motors going bad, or contactors (solenoids) going bad. It sounds like you've got one or both of those problems. From what I've read, a bad motor is a blessing in disguise, and many people take that opportunity to upgrade to a 3 phase motor and variable frequency drive (VFD) controller. Good luck on the repairs.
A Wonderful day in central Wisconsin Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 31 11-01-2008 08:25:26 PM
Where to get coal in Central Indiana? steif Steam Stationary Engines, Traction Engines 7 07-11-2008 09:26:17 PM
Lawnmower Central Austen Garden Tractors and Mowers 3 02-19-2006 12:38:56 PM
Central Mass Show Ernie Antique Engine Archives 4 06-30-2002 08:25:28 AM
Central City, Neb. arney Antique Engine Archives 3 10-29-2001 09:58:04 PM
