Old Sheet metal brake help
this thread has 3 replies and has been viewed 6366 times
Old 11-30-2008, 05:19:01 PM
Frank Y's Avatar
Frank Y Frank Y is offline
Default Old Sheet metal brake help
Picked this up a few months back at a retired machinists sale. Son was selling everything off and picked up stuff I never thought I would get a chance at. This was in one of the sheds. It came "literally" in a box. Dad used to use it to make dripedge and soffit. I was hoping I can rebuild it and start making my own gas tanks. Can anyone help in the assembly? I have NO IDEA where to start putting the pieces. Maybe someone has one like it that can share pics. There are no maker names but some main castings have a small diamond with a "P" cast in.
Thanks for any help!
Old 11-30-2008, 08:00:09 PM
Jan4CMF Jan4CMF is offline
Default Re: Old Sheet metal brake help
It looks to melike you have what is left from an old wooden brake. I've only ever seen one once before and it looked to be pretty good shape till we tryed to move it . Well it had grown roots and was all dry rotted. I think these brakes were made for very thin sheet metal.
Good luck with your project. Jan
The Following User Says Thank You to Jan4CMF For This Post:
Old 11-30-2008, 08:38:31 PM
John Delbert Hidy John Delbert Hidy is offline
Email NOT Working
Frank I did sheet metal for 26 and a half years. P==may stand for pexto they made a lot of sheet metal tools.--John
Old 12-09-2008, 09:54:16 PM
Frank Y's Avatar
Ok, so maybe when you get so frustrated with something and keep coming up with the stupidest way to put something together and trying new things something actually comes out of it.
I think i may have put this thing together...mostly. I sat down one evening and just started looking at the pieces and the worn points. Sanded some rust off and it came together. Now I just need to add wood. BUT I can tell you that I never used a brake much less a wooden one so I still dont know where the steel "bending" pieces go. Can someone enlighten me here? I still cant exactly see how the thing works. I know the smaller rod and ball acts like a clamp of sorts and the big rod and ball is the Balance.
ID:	44739   Click image for larger version
Sheet Metal for Onan 30.0EK 15R bsme3 Onan Generators 0 09-16-2008 12:12:40 PM
Sheet metal stack Alan New Steam Stationary Engines, Traction Engines 1 07-10-2007 05:16:55 PM
sheet metal work (20-30 Rumely) Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 12-18-2006 11:09:52 PM
9/18 Case sheet metal Jerrod Werth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 06-30-2006 09:26:24 AM
New Way sheet metal Jim Sherman Antique Engine Archives 1 02-02-2000 04:54:58 PM
