Bearing Material Selection
this thread has 2 replies and has been viewed 1937 times
Old 12-13-2008, 07:04:12 PM
Rex Piekarczyk's Avatar
Rex Piekarczyk Rex Piekarczyk is offline
Question Bearing Material Selection
I need to make new flanged bearings for my mower deck wheels and spindles They're grease lubed and run through sand mole hills and have to be replaced every year. I have a Bunting Bearings catalog wihich lists several alloys of cored bronze bar stock, but don't know which would be best. Any ideas?
Rex
Old 12-13-2008, 09:05:42 PM
wayne m. wayne m. is offline
Default Re: Bearing Material Selection
Teflon, Delrin, Nylatron, Polyamid,etc all of these would be superior over a greased bearing these require no grease and are self lubricating materials therefore they are resistant to picking up gritting materials such as sand, dirt, and dust. In addition these should have approx .010-.012 clearance to shaft and wear will be superior with no maintenance.And the price is relatively cheap. AIN plastics on a google will hook you up or McMaster-Car.
The Following User Says Thank You to wayne m. For This Post:
Old 12-13-2008, 09:24:14 PM
I think I've got some nylatron to try. Another site suggested Rulon. Never heard of that one.
Bearing Box Material - "Waste" Larry Mix Steam Stationary Engines, Traction Engines 19 07-29-2008 11:51:30 AM
DJE Manual Selection Nazrat Onan Generators 0 08-25-2007 12:01:58 PM
book selection jager Antique Engine Photos 2 06-21-2007 02:40:36 PM
Conn-Rod Bearing Material?? Marvin S Hit & Miss Gas Engine Discussion 5 10-11-2006 10:18:30 PM
VALVE MATERIAL allen lapage Antique Engine Archives 7 09-13-2002 08:07:24 PM
