Core Drill (pilot drill bit)
this thread has 10 replies and has been viewed 4110 times
Old 12-21-2008, 11:07:40 PM
bruce burgess bruce burgess is offline
Default Core Drill (pilot drill bit)
hi
would anybody know of a supplier who sells Core Drills ?
thanks bruce
Old 12-22-2008, 12:14:06 AM
Default Re: Core Drill /pilot drill bit
should have discribed as pilot drill bit
bruce
Old 12-22-2008, 12:35:28 AM
John A John A is offline
Have you tried Grainger.
www.grainger.com
They almost everything you can think of for home and industrial use.
John
Old 12-22-2008, 12:38:24 AM
Sorry www.acklandsgrainger.com in Canada. Showing 155 locations.
800-668-8989
John
Old 12-22-2008, 12:45:14 AM
thanks john
acklands grainger in canada once did sell these and many machine shop items but since they dropped there in store machine shops it seems they dont have them in thier catalogues or at least engine building type stuff.
i tried a search on your link but it seemed i needed to log in to really get in to have a look.
bruce
Old 12-22-2008, 12:51:54 AM
Bruce try the 800 number tomorrow.
I got this information out of catalog 399. 2008-2009 edition.
If not they might be able to tell you where you can find one locally.
Also some tool rental stores also carry pilot bits and core drills when the rental customers break one, they bought it.
John
Old 12-22-2008, 12:58:27 AM
try www.granger.com and see if they carry it in the lower 48.
john
Old 12-22-2008, 01:01:51 AM
Or www.victornet.com
Machine shop tool supplier.
John
The Following User Says Thank You to John A For This Post:
Old 12-22-2008, 01:03:12 AM
john
the item im trying to describe is a piloted drill bit for drilling out valve guides to insert new guides which are larger than the original stem holes.
thanks bruce
Old 12-22-2008, 12:04:09 PM
Matt Montague Matt Montague is offline
Try these guy's, http://www.goodson.com/
Matt
The Following User Says Thank You to Matt Montague For This Post:
Old 12-22-2008, 02:22:05 PM
wayne m. wayne m. is offline
Default Re: Core Drill (pilot drill bit)
Try www.mscdirect.com
The Following User Says Thank You to wayne m. For This Post:
drill sizes Eric Schultz Hit & Miss Gas Engine Discussion 23 02-26-2007 11:21:31 PM
Drill to start? 1911_75_CASE Hit & Miss Gas Engine Discussion 32 12-25-2006 10:51:35 AM
drill bit sharpeners Leonard Keifer Machine Shop and Tool Talk 27 12-04-2006 12:45:10 AM
Drill size for tap Chris Kirk Antique Engine Archives 9 07-28-2002 09:08:52 PM
How to Drill a Hole?? WILL Antique Engine Archives 26 02-26-2002 12:00:13 PM
