Fairbanks Morse 1.5 headless ignitor fouling
this thread has 11 replies and has been viewed 689 times
Old 11-17-2019, 10:10:45 PM
Reddog15 Reddog15 is offline
Default Fairbanks Morse 1.5 headless ignitor fouling
Hello,
Had my FM running at a show for the first time and had problems with the ignitor becoming fouled with carbon regularly. I would clean the contacts and it would run for about 5 minutes and then die. Lather, rinse, repeat. What is the most likely cause of this? The mix didn't seem overly rich since I didn't see any black smoke out the exhaust.
Old 11-18-2019, 07:33:37 AM
G.M.Johnson G.M.Johnson is offline
Default Re: Fairbanks Morse 1.5 headless ignitor fouling
I have a FM 3-hp z that sat for many years and once I got it running again the ignitor would foul out in a short time due to all the carbon build up coming off the head and the little pieces would get in the ignitor.
Old 11-18-2019, 08:28:46 AM
Originally Posted by Reddog15 View Post
Hello,
Are you running the engine on magneto or battery and coil? If battery and coil, too much amperage can "burn" the contacts causing the engine to stop a few minutes after cleaning the ignitor. Also make sure that the ignitor shaft isn't getting sluggish from carbon/gum.
Old 11-18-2019, 10:43:17 AM
Kirk, I'm running a 12 volt battery and coil. I'm a bit rusty on Ohm's law, if I went to a 6 volt would that cut down on the potential burning?
Old 11-18-2019, 12:54:43 PM
MColopy MColopy is offline
Ohms law tell us that watts(power) = volts x amps.
If you cut voltage in half the power to the contact would be cut in half. All the old cars with points used a ballast resistor to keep from burning up the points, you might try one on it and see if that helps.
Old 11-18-2019, 01:14:44 PM
Thanks! I'll give that a try.
Old 11-18-2019, 02:12:45 PM
Fry gray carbon? Wet black? Oily black? For oil, you need SAE 30, about 6 to 8 drips a minute. As long as the piston is wet with oil, you are good. Too much oil or multigrade will foul the ignitor. Ignitor wet with gas is self explanetory - it is running too rich. Dry gray deposits mean too rich and too cool. These engine were not meant to idle with no load for long periods, they need to work!
Old 11-18-2019, 07:59:26 PM
Dry black carbon and some pitting on the points. I'm going to figure out how to make my coil less hot and also figure out how to provide a load. I don't currently have anything to run with it. Are there good ways to provide a load without anything to run?
Old 11-18-2019, 09:03:56 PM
Family Tradition Family Tradition is offline
Hold a 2x4 to the pulley or fly wheel
The Following User Says Thank You to Family Tradition For This Post:
Old 11-18-2019, 10:39:54 PM
Dan Baalman Dan Baalman is offline
Timing issues can cause this as well.
Old 11-19-2019, 06:14:51 PM
Old Iron Dave Old Iron Dave is offline
halfing the voltage will result in halfing the current which will then result in one fourth the power. P=ExE/R, P=IxIxR, P=IxE.
The Following User Says Thank You to Old Iron Dave For This Post:
Old 11-22-2019, 09:27:21 PM
Update; tested the ignitor today while out of the engine with a ballast resistor and it looks to have tamed the spark fairly well. Still blue but not as intense. I'll give it a try once I get my fuel feed ironed out.
Fairbanks-Morse Headless Ignitor Roger Eldred Hit & Miss Gas Engine Discussion 0 11-22-2018 08:45:14 PM
Adjusting the Ignitor timing on a headless fairbanks morse Lanzb Smokstak Down Under 4 07-31-2011 05:31:13 AM
Fairbanks Morse Headless Ignitor Rebuild Jim Gorter Hit & Miss Gas Engine Discussion 15 12-09-2010 02:19:56 PM
Rebuilding Fairbanks Morse Headless Ignitor Bob Johnson Hit & Miss Gas Engine Discussion 1 08-10-2008 07:06:09 PM
Fairbanks headless ignitor help ssimntih Hit & Miss Gas Engine Discussion 5 10-18-2005 03:54:37 PM
