Ice Cream Freezer Engine HP to Churn Capacity.
this thread has 6 replies and has been viewed 628 times
Old 11-17-2019, 11:10:34 PM
Mike Paul's Avatar
Mike Paul Mike Paul is offline
Default Ice Cream Freezer Engine HP to Churn Capacity.
I didn't want to hijack Farmer John's thread but I have a few questions regarding engine size to churn capacity. I have a five gallon White Mountain freezer and I don't want to inadvertently ruin the gear head by overpowering it when the mix freezes up. Is there a preferred way to incorporate a shear pin or mechanical cutout into the pulley system to protect the churn? What engine sizes work well with different type churns? I have a 3HP IH M that should be more than enough to drive a five gallon but would a Maytag work as well?
Old 11-18-2019, 12:32:55 PM
Stuhly Stuhly is offline
Default Re: Ice Cream Freezer Engine HP to Churn Capacity.
I run a 3 gallon with a 11/2 JD. When the ice cream sets up it will slip the single V belt.
The Following 3 Users Say Thank You to Stuhly For This Post:
Old 11-18-2019, 12:36:16 PM
Jason Dahm Jason Dahm is offline
I can't supply a definitive answer but I will suggest that the 3hp M would be much more pleasant on the ears than the Maytag!
The Following 3 Users Say Thank You to Jason Dahm For This Post:
Old 11-18-2019, 01:17:08 PM
GreasyIron GreasyIron is offline
Not at all first hand information here, but, somewhat like the V-belt above, I've heard from more than one source that the ice cream is ready when the flat belt is thrown.
Good luck! You're making me hungry for things that stick too well to my waist line.
Old 11-21-2019, 10:09:51 AM
Mike Paul's Avatar
Jason, I just changed your ring tone to a Maytag engine.
The Following User Says Thank You to Mike Paul For This Post:
Old 11-21-2019, 10:51:28 AM
I will be calling you much more frequently and you should soon see my point!
When you have finalized your freezer setup I will not turn down any of the product no matter what engine is pulling it!
Old 11-21-2019, 12:21:52 PM
KeithW's Avatar
KeithW KeithW is offline
My Briggs engine runs two 6 quart makers with less than one horsepower. On the belt drive I put the spring tensioner idle pulley on the tension side rather than the slack side. That way when the torque gets too high the belt is loosened and slips.
The Following User Says Thank You to KeithW For This Post:
Another Ice Cream churn Fred Van Hook YouTube Old Iron Videos 0 02-23-2019 10:07:03 PM
6 Quart Ice Cream Churn Restoration HermitFlywheel Farm Antiques and Collectibles 23 09-09-2016 04:45:03 PM
IHC LB Engine powered 20 Quart Ice Cream Freezer Wagon dryan117 Hit & Miss Gas Engine Discussion 3 07-21-2015 10:21:01 AM
john deere 1.5 e engine / gear reducer for ice cream churn vanceoutlaw Hit & Miss Gas Engine Discussion 1 02-23-2014 05:37:25 PM
H & M and Ice cream Churn Alvin Poston Antique Engine Archives 14 06-01-2001 08:48:59 PM
