Briggs and stratton model BP
this thread has 3 replies and has been viewed 1042 times
Old 09-30-2016, 09:02:43 PM
tomboy tomboy is offline
Default Briggs and stratton model BP
I got this briggs at an auction, I can't find anyting listed as model BP, type # 300504, ser # 103775. It has a crank start, slab head, mec fuel pump, the air shroud is all cast iron. Its got a longer crank shaft, and was a kohler generator, that tag says, kohler mod 800 M21, 800 watts, 110- AC, 1800 rpm's, 60 cycle, with a ser # of 99437. Does anybody have any info on this engine?
The Following User Says Thank You to tomboy For This Post:
Old 09-30-2016, 11:37:38 PM
Vanman Vanman is offline
Default Re: Briggs and stratton model BP
That's a Model B. The P indicates direct mounting to the crankcase, ie how the generator mounted to the engine.
According to this website http://www.oldengine.org/members/murphy/model_b.htm
yours was made in 1944. Can also date by the Kohler serial number, but I don't have that list in front of me.
It is too bad that the generator is missing, they are great little sets. Here's mine:
https://www.smokstak.com/forum/showthread.php?t=121228
And here's mine running some bulbs and a fridge during a power failure:
https://www.youtube.com/watch?v=ueywqrf8xP0
And no, I was NOT the one who painted it in those carnival colors!!!
Keith
Old 10-01-2016, 09:09:15 AM
Thanks vanman for the info, a few things are missing, like the carb and fuel pump, it turns over, and what supprises me is the starting mec is as solid as new, no slack in the crank bushing at all, and no cracks or welds on the air shroud.
Old 10-01-2016, 11:02:33 AM
Vanman is correct. It is a model B Briggs & Stratton. I have the same setup as both of you. Vanman and I have talked about this engine / generator setup before. I have too busy to take the time to run mine.
Briggs and Stratton Model ZHL willswhatnots Small Air Cooled Gasoline Engines 14 06-10-2015 09:58:23 AM
Briggs & Stratton model K Restofire Small Air Cooled Gasoline Engines 4 04-03-2013 11:06:53 AM
Briggs & Stratton Model Y dirtycurt Small Air Cooled Gasoline Engines 1 11-28-2011 09:16:10 AM
Briggs & Stratton Model 14 grnlark Garden Tractors and Mowers 3 01-08-2011 05:31:43 PM
Briggs and Stratton model A Travis Small Air Cooled Gasoline Engines 11 02-09-2009 09:13:13 PM
