FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit?
this thread has 4 replies and has been viewed 3902 times
Old 09-11-2008, 11:08:43 PM
LShap1777 LShap1777 is offline
Default FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit?
Hi Guys,
Started a new thread for a part. I have a throttled Morse Fairbanks 3 hp type c Z engine. Ser # 833745. 1942? approx. I need the "main bearing liner-lower" part #zac23d-which is the lower support main bearing .
Ed(Hit and Miss), can not get it. I have the old part, and it was cracked in two, the long way. I am reluctant to run the engine with this cracked part. I JB welded it together, but I do not think this will hold up when the engine is running. If anyone has this, I will be glad to buy it. I got this engine siezed, and this is my first engine. I just do not want to take a chance with such an integral engine part.
Any input?
Thanks,
Larry
Name:	lower babbit 011.jpg
Old 09-12-2008, 12:38:50 AM
Ray Cardoza's Avatar
Default Re: FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit?
do you have access to a lathe? there might be someone out there who could make it out of bearing grade bronze or make the back part of the bearing and line it with the babbited part for you. good luck
Old 09-12-2008, 08:58:45 AM
David M. Lyon's Avatar
Looks like a "ZC" bearing. Aren't the upper and lower bearings identical? Swap them!....Put the good one on the bottom to support the crankshaft, and place the cracked one on the top shell. Shim up the bearing good an snug and RUN IT!....Unless your're gonna' work the engine hard, I doubt it will ever hurt a thing.
Jus' my two cents.
Old 09-12-2008, 10:36:59 AM
Elden DuRand's Avatar
Jus' my two cents.
I agree!
If it's only cracked and not broken in two, it will be fine.
Take care - Elden
http://www.oldengine.org/members/durand/
Old 09-12-2008, 11:03:58 AM
Hi Guys,
The bearing was cracked in two pieces. The top and bottom bearings are not the same. I JB welded them back together. I suppose I could try it the way it is. I mean, what's the worst that could happen? Has a noise, I shut her down.
Thanks,
Larry
New Guy Restore 1942 Fairbanks Morse Type c Z 3 hp LShap1777 Hit & Miss Gas Engine Discussion 17 09-07-2008 05:37:36 PM
Fairbanks Morse Head part number Stevie Hit & Miss Gas Engine Discussion 0 03-18-2008 09:53:44 PM
Fairbanks Morse ZB Brian D. Hit & Miss Gas Engine Discussion 10 04-20-2007 01:41:09 PM
Fairbanks morse part number help Scott Hit & Miss Gas Engine Discussion 0 04-27-2005 07:11:17 PM
Fairbanks&Morse Aaron Antique Engine Archives 2 01-06-2001 05:20:19 PM
