Paint Shop
Help on repainting an Onan gas tank
this thread has 5 replies and has been viewed 2609 times
Old 09-27-2011, 01:19:17 AM
jeep2001 jeep2001 is offline
Default Help on repainting an Onan gas tank
I just bought a AJ 2500 Onan generator, the gas tank paint is not in good shape, the thak is red and the rest on the generator is green. What would be the best steps on repainting the gas tank?
Thanks Mike
Old 09-27-2011, 02:51:47 AM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: Help on repainting an onan gas tank
strip sand repair prime paint with gas resistant paint basicaly
Old 09-27-2011, 07:37:49 PM
Could I use the Onan spray can and then clear coat it? Will the clear coat stand up with gas?
Thanks Mike
Old 09-27-2011, 08:44:37 PM
ehpower2's Avatar
all depends on if the clear coat gas resistant.
Old 09-28-2011, 08:59:33 AM
Clement Rook Jr. Clement Rook Jr. is offline
i use minwax clear polyurethane gloss or semi gloss in a rattle can to over spray any part of a engine i want to make gas proof . scuff sand the part with a extra fine scotch brite after the finish paint is thoroughly dry,then over spray with two or three light coats of polyurethane. this brings the gloss back and seals the paint. works for me!
Old 09-28-2011, 01:22:27 PM
Default Re: Help on repainting an Onan gas tank
Thanks everone for the help, do I have to be real carefull sanding the tank? I did not want to sand too much on the seems because I didnt want any leaks. Are these tanks heavy enough not to worried about this?
Mike
70 KW Onan - How big of propane tank required richard.bessey Onan Generators 6 04-28-2008 11:48:09 AM
Repainting a running engine BobM Hit & Miss Gas Engine Discussion 5 02-10-2008 08:45:00 PM
Repainting a 1 HP Famous Farmall Hit & Miss Gas Engine Discussion 9 06-01-2005 10:47:28 PM
Repainting a really badly painted engine Bob R. Antique Engine Archives 4 07-29-2004 08:37:56 AM
Repainting the Engine... Jeffrey Paint Shop 1 11-06-2002 03:17:44 AM
