Repainting my IHC M
this thread has 11 replies and has been viewed 2548 times
Old 10-06-2011, 10:28:18 AM
robert hamilton robert hamilton is offline
Default Repainting my IHC M
Hi all the other day a can of paint stripper exploded in my shed covering my international and ruined the paint so iv decided to repaint it i want to paint it IHC red but i want it to be a really shiny finish but there are lots of pits in the casting how should i go about filling and smoothing them out
Old 10-06-2011, 11:56:00 AM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
Default Re: Repainting my IHC M
"M"s could be red originally, in case someone objects. This one even had the original decals. The black flywheels and head were painted later.
I've even seen a blue, Osborn "M" but don't know of the story behind that one.
Name:	1.5 hp M 0005.jpg
The Following 4 Users Say Thank You to John Hamilton For This Post:
Old 10-06-2011, 06:10:47 PM
SDP's Avatar
SDP SDP is offline
Does that original decal say McCormick or International on your red engine? Thanks for posting!
"Liberalism is the transformation of mankind into cattle."
Friedrich Wilhelm Nietzsche (1878)
Old 10-08-2011, 11:51:10 AM
The decal was McCormick-Deering. Seems like it was a 1932 engine but it's long gone and this is the only photo.
The Following User Says Thank You to John Hamilton For This Post:
Old 11-12-2011, 08:06:18 AM
Iv got the second coat of grey on it now i was thinking of doin 5 coats of grey them 6 or 7 coats of red then a clear coat
Old 11-12-2011, 08:08:19 AM
oops i forgot the picture
Old 11-22-2011, 03:12:53 AM
Iv just put the second coat of red on my International im going to put another four coats of red on then two coats of clear it should look good when im done
ID:	121447   Click image for larger version
ID:	121448   Click image for larger version
The Following User Says Thank You to robert hamilton For This Post:
Old 06-03-2012, 08:19:06 AM
Hatman Hatman is offline
Hi mate,
Great job with the paint on the M. Looks sensational! I have just bought a 1 1/2 M today which was badged as a McCormick Deering IHC and thus is still in its working clothes of green with red painted oil caps and a black painted head. Apparently that is how they were delivered over here. Can just still make out the original decals. In two minds as to whether to leave it as it is and coat it with hydraulic oil or do a "Hamilton" and do a Mickey mouse paint job. I'm leaning towards the new paint after seeing your efforts.
The Following User Says Thank You to Hatman For This Post:
Old 06-03-2012, 08:33:29 AM
John Savot John Savot is offline
What kind of primer, paint and clear coat are you using?
John
The Following User Says Thank You to John Savot For This Post:
Old 06-04-2012, 02:07:20 AM
animals animals is offline
hi if you really want it smooth spray it with surface primer and sand it down start with 80 grit spray it again and keep useing finer and repeat the process until its as smooth as glass eventuly you should use 400 grit it will really shine good luck
The Following User Says Thank You to animals For This Post:
Old 06-04-2012, 03:08:13 AM
John
I used dulux grey sanding primer and wattle KillRust delicious red
---------- Post added at 07:08 PM ---------- Previous post was at 07:04 PM ----------
Originally Posted by Hatman View Post
Hi mate,
Thanks it has taken a while to get it just right i put about 6 coats of primer and 10 coats of red might i ask what is a hamilton
Old 06-04-2012, 03:47:39 AM
Merv C Merv C is offline
G'day Robert,
About twenty years ago I went all out on my 3hp M circa 1920.
I normally don't go to this much bother repainting a engine, but the finish came up like glass and even now it still looks good.
This photo was taken last year at the Tapanui rally in Southland.
Merv
[IMG][/IMG]
The Following User Says Thank You to Merv C For This Post:
Help on repainting an Onan gas tank jeep2001 Paint Shop 5 09-28-2011 01:22:27 PM
Repainting a running engine BobM Hit & Miss Gas Engine Discussion 5 02-10-2008 08:45:00 PM
Repainting a 1 HP Famous Farmall Hit & Miss Gas Engine Discussion 9 06-01-2005 10:47:28 PM
Repainting a really badly painted engine Bob R. Antique Engine Archives 4 07-29-2004 08:37:56 AM
Repainting the Engine... Jeffrey Paint Shop 1 11-06-2002 03:17:44 AM
